cant get into any gears, why???
Old Jun 26, 2008 | 10:38 AM
theslugbug's Avatar
Default cant get into any gears, why???
i was driving day, stop at a light and when it turned green, i couldnt shift into any gears. need help or suggestion ASAP
Old Jun 26, 2008 | 10:43 AM
4g hatch's Avatar
Default Re: cant get into any gears, why??? (theslugbug)
check your tranny oil level
Old Jun 26, 2008 | 10:54 AM
theslugbug's Avatar
Default Re: cant get into any gears, why??? (4g hatch)
how do i do that???
Old Jun 26, 2008 | 10:59 AM
theslugbug's Avatar
i smelt my clutch burning yesterday on the freeway too for like a minute. can my clutch be bad??
if its not the fluid, than i need to go buy a clutch set but really short on cash and dont want to buy it if i can get a cheap fix. help ASAP, i need my car running tomorrow. im trying to fix whatever i can today.
Old Jun 26, 2008 | 12:00 PM
theslugbug's Avatar
BUMP... need help or suggestion asap....
Old Jun 26, 2008 | 12:21 PM
00Red_SiR's Avatar
All Motor Mentor
sounds like your clutch is done. Check your clutch fluid to make sure it's not low and make sure the slave moves when you press the clutch. If these are ok, you need a new clutch pressure plate and disk.
Old Jun 26, 2008 | 12:41 PM
theslugbug's Avatar
where is the clutch slave located??? the fluid is there tho. what happens if the slave doesnt work?
Old Jun 26, 2008 | 12:53 PM
JakeSpec's Avatar
bad pressure plate.....
Old Jun 26, 2008 | 01:04 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theslugbug &raquo;</TD></TR><TR><TD CLASS="quote">where is the clutch slave located??? the fluid is there tho. what happens if the slave doesnt work? </TD></TR></TABLE>
It's located on the front of the engine where the transmission joins it. If it doesn't work, your clutch won't engage.
I'm betting that you need a new clutch though.
Old Jun 26, 2008 | 02:44 PM
theslugbug's Avatar
Default Re: cant get into any gears, why??? (00Red_SiR)
okay, i didnt hav clutch fluid in there. so its in there now. i can shift into gears when the car is off but not on.
i still dont know how to check the clutch slave tho. how asap.
Old Jun 26, 2008 | 03:09 PM
theslugbug's Avatar
i dont get how i suppose to see the slave move. i tried it on both honda's i hav and then i tried it on a toyota and the toyota works, it moved and i can see it. i dont know how to tell if it works on the honda's tho, no moving parts
Old Jun 26, 2008 | 03:24 PM
00Red_SiR's Avatar
All Motor Mentor
If you had no fluid it means you have a leak, which means your clutch master cylinder is probably shot. Even though you put fluid in there you didn't bleed it so the air is preventing the clutch from operating. You'll need to replace your clutch master cylinder.
Old Jun 26, 2008 | 04:00 PM
theslugbug's Avatar
for sure that is what i need to do? replace the master clutch slave? is there a way i can fix it so it works? i can get the car to go into gear but i have to step on the clutch super hard to get it in gear. i dont know what to do.
are all clutch master cylinder the same?
Old Jun 26, 2008 | 04:26 PM
theslugbug's Avatar
can i bleed it now?
Old Jun 26, 2008 | 09:28 PM
theslugbug's Avatar
bleed it, it works now. change out the master cylinder and slave soon tho. thanks for the help yo. peace.
kojack_0
Feb 10, 2010 12:39 PM
Superman137
Feb 17, 2006 02:02 PM
KRAP DIVAD
Sep 4, 2005 05:10 PM
ninety9ex
May 3, 2004 02:01 PM
