Received Bad Mount from Hondaautomotiveparts.com? Take a Look
So I ordered a bunch of things and they shipped it all in a small box with no packaging and it was bouncing around on the inside. Everything seemed to be fine except for the lower driver's side mount I ordered.
I'm not sure if this is supposed to be like this?...Pictures are a little blurry because it is still in package...
Top Right of Mount
Top Left of Mount
Bottom Middle of Mount
Modified by lmike6453 at 8:54 AM 6/26/2008
Top Right of Mount
Top Left of Mount
Dont worry, they are fine. I just bought mine from the dealer and they look like that too. That's just a thin layer of whatever they use to coat the rubber on them. As long as the 3 rubber pieces extending from the center are good, then the mount is good.
Not sure what year integra you have, but heres what a mount looks like from my 91 integra. This is the front tranny mount (sits in the middle, bolts to the crossmember)...I can see where some might construde these as "bad mounts"...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">Can't take any better pics; I tried. If you look in the background of the room, you will see how clear it is.</TD></TR></TABLE>
L2use Macro. You should have a setting on your camera that has an icon similar to a flower. Use it for these kind of pictures
