Problem after new clutch cylinder!!!
Old Jun 26, 2008 | 06:28 AM
aemintgsr's Avatar
Default Problem after new clutch cylinder!!!
I installed a new clutch master cylinder and the pedal is to the floor and it acts like there is no pressure it just stays down there. you could grab the pedal and shake it back and forth like nothing. This afternoon im going to bleed it with that bleeder tool to see if thats my problem, any suggestions??
Old Jun 26, 2008 | 07:08 AM
all-mtr-teg's Avatar
Default Re: Problem after new clutch cylinder!!! (aemintgsr)
Did you bleed it after you installed the new one?
Old Jun 26, 2008 | 07:25 AM
aemintgsr's Avatar
Default Re: Problem after new clutch cylinder!!! (all-mtr-teg)
No because it feel like there is no pressure to bleed
Old Jun 26, 2008 | 07:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemintgsr &raquo;</TD></TR><TR><TD CLASS="quote">I installed a new clutch master cylinder and the pedal is to the floor and it acts like there is no pressure it just stays down there. you could grab the pedal and shake it back and forth like nothing. This afternoon im going to bleed it with that bleeder tool to see if thats my problem, any suggestions??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Did you bleed it after you installed the new one?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemintgsr &raquo;</TD></TR><TR><TD CLASS="quote">No because it feel like there is no pressure to bleed
Let me get this straight, you installed a new ctutch cylinder and didn't bleed it? Now you're asking why there isn't any pressure on the pedal? Are you familiar with how a hydraulic system works?
A hydrolic clutch system is similar to your brake system. Water and fluids such as brake and clutch fluid aren't compressible. If there is air (which is compressible) in the system you will not build pressure as you apply the pedal. Therefore you must bleed the system anytime air is introduced into the system (such as when disconnecting a hose or replacing a cylinder).
Have someonoe who is more mechanically inclined give you hand. It is much more easier to bleed a system with 2 people anyways. 1 to pump the pedal, the other to keep the reservoir full.
Old Jun 26, 2008 | 09:22 AM
aemintgsr's Avatar
Thats what i thought, so this after noon im going to buy the tool that bleeds hydralic systems. Thanks
ill keep posted
Old Jun 27, 2008 | 06:21 AM
aemintgsr's Avatar
Found out it had a lot off bubbles and i couldnt of done it with out the one man bleeder kit.
Old Jun 27, 2008 | 06:23 AM
Default Re: (aemintgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemintgsr &raquo;</TD></TR><TR><TD CLASS="quote">Found out it had a lot off bubbles and i couldnt of done it with out the one man bleeder kit.</TD></TR></TABLE>
Yes you can, just would have taken a while
IgnitionZ05
Dec 8, 2006 11:27 PM
matto2413
Sep 11, 2005 09:01 PM
LCDeuce
Feb 9, 2005 11:14 AM
HONDADRAGONSTAR
Aug 18, 2004 07:25 PM
Ryan C
Jun 11, 2004 01:16 PM
