Y merge
Old Jun 25, 2008 | 11:23 PM
NoClassic's Avatar
Default Y merge
I know this has been discussed here before, but the search function will not allow for anything less than two characters (Y).
Im going to start constructing the exhaust on my 5.3 S13 soon and its going to need a 2.5" Y merge to transition the two B pipes into the 4" rear section. I know the 2.5" to 4" seems odd but the rear section is in preparation for future forced induction.
Can anyone provide any examples of proper Y merge construction, or maybe even work one up for me? It does not need to be anything special seeing that in time it will be scrapped for the turbo manifolds and a single downpipe.
Old Jun 26, 2008 | 02:07 AM
welfarepc's Avatar
weld two pips into a V, cut off the bottom, and weld another pipe onto that. done
Old Jun 26, 2008 | 02:16 AM
jzz30's Avatar
or you can get 2, 90 degree bends or 45 degree bends or whatever depending on your angle needed and cut one of the straight sections in half for both tubes and weld them together.
Old Jun 27, 2008 | 01:20 PM
Top Ramen's Avatar
Default Re: (jzz30)
From Burns:
Old Jun 27, 2008 | 02:22 PM
NoClassic's Avatar
I found the same image last night. Cant think of a better example to use as a model.
b18cya94
Welding / Fabrication
24
Mar 26, 2013 05:41 AM
TurboSI56
Jul 12, 2006 01:01 PM
deeweezy187
Feb 4, 2006 12:44 PM
1SlowSi
18
Dec 21, 2004 11:04 PM
VanHonda
Apr 13, 2004 05:01 PM
