headstud threads in block are stripped??
Old Jun 25, 2008 | 11:06 PM
iwantspeed's Avatar
Default headstud threads in block are stripped??
what do i do now? helicoil? it looks like i need a long tap. does this happen often?
Old Jun 25, 2008 | 11:35 PM
immorality's Avatar
Default Re: headstud threads in block are stripped?? (iwantspeed)
I would start with a normal tap (assuming you have one) and if need be you can use a bottoming tap to get the threads right to the bottom of the hole (although I doubt Honda went to that extend). If you can't clean up the threads then a helicoil would be the next step. If that doesn't work you will have to bore the hole out to the next larger size.
Ser1N
Apr 27, 2012 09:51 AM
-iLLuZioN-B18C1
Aug 4, 2004 06:19 AM
pip9
Jun 15, 2004 03:58 PM
brinks
May 19, 2004 03:39 PM
JDMkid32
Mar 8, 2004 12:31 AM
