Weird problem please help
ok so i have a civic that had a ls turbo. I took the turbo kit off and decided to go to stock. Today I finally start the car and my blinker lights do not work, my fuel guage shows all the way empty but there is gas in the car, and my A/F gauge shows rich once started but then switches all the way to lean and stays there. Please help thanks in advance
do your RPM and temp gauges work? How about your parking lights? My cousin had the same problem recently, found out his fog lights, which are connected to his parking lights, were touching somewhere, causing the entire lighting system to malfunction, basically nothing worked...
If you're blinkers don't work, and the lights in your dash don't work, there is a fuse for the instrument panel, license plate lights, etc, all in one, I'm sure that would be bad, just change it out and should be good.
Just turn on your parking lights, and go to the back of the car and see if youre license plate lights are working, if not, it's the fuse most likely. Something just touched somewhere when you removed the turbo, either that or even before, could be straight coincedence.
yea i checked my parking lights and they works except for the blinker lights. I also checked the gauge cluster and nothing works except for the lights that light up the cluster at night. So I will change the fuse tomarrow. thanks alot
i tried putting a fuse into the fuse panel where the 19 slot is and there was no fuse there befor so any one know what the problem could be since everything use to work befor
EFLX
Jun 13, 2010 08:21 PM
tearinox
Oct 25, 2008 05:13 PM
mitsurugi
Dec 4, 2006 08:05 PM
NatedoggAZ
Feb 10, 2006 11:00 AM
dturbo
Mar 22, 2005 02:57 PM
