S2K Airbag wiring
I just installed a S2K steering wheel on my 96 Accord coupe. The problem is that the airbag wires were cut from the s2k factory connector. I'm assuming the guy I bought it from couldnt figure out how to disconnect it properly. I was just going to cut the connector off my accord airbag and splice it onto the s2k airbag and plug it in but....my question is, does anyone know if there is a +/- polarity to the airbag? Both wires are red from the airbag but the connector to the accord is black/green or is black/yellow? Theres nothing on the airbag itself to identify if there is a +/- wire. I'd appreciate anyones suggestions. Thank you in advance.
I wouldn't mess around with the airbag. Just pull the SRS bulb or get a new airbag. Its not worth killing yourself over if it desides to go off while driving.
