M&H Bias Ply DOT tire pressures?
Old Jun 25, 2008 | 08:04 PM
Tchleung's Avatar
Default M&H Bias Ply DOT tire pressures?
Just curious what tire pressures you guys run your M&H Bias plys at? I've been running them on 14psi hot as it gave me the most contact patch, but I never went lower then that, it seems some people go way down below 10 even. What do you guys run?
Old Jun 25, 2008 | 09:13 PM
Boner_Ben's Avatar
Default Re: M&H Bias Ply DOT tire pressures? (Tchleung)
I would run them around the same pressure as you would run slicks- between 6-8 psi. At 14psi, they are not wrinkling one bit.
Old Jun 26, 2008 | 01:50 PM
nonvtecallmotor's Avatar
I ran the M&H 235's at 6psi. I went the best of a 1.73. The car stayed in the mid 1.7's. You must do a 3rd gear burnout.
Old Jun 26, 2008 | 03:39 PM
Tchleung's Avatar
3rd gear lol. I've just been doing 2nd gear burnouts, although I hold the burnouts for a long time tho.
Old Jun 26, 2008 | 05:58 PM
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">3rd gear lol. I've just been doing 2nd gear burnouts, although I hold the burnouts for a long time tho.</TD></TR></TABLE>A rolling burnout will get them hotter.....
Old Jun 26, 2008 | 07:13 PM
Tchleung's Avatar
Yeah I start the burnout and get it gonig good in the water box and let it pull itself out a bit into the dry, then slowly release the ebrake and continue the burnout till just before the lights. It's a fair burnout
extremeracer
Mar 25, 2011 02:10 PM
kun3racer
Jul 26, 2004 06:37 PM
V-SPEC 1
Jun 7, 2004 07:58 AM
V-SPEC 1
Jun 6, 2004 07:56 PM
RacerMike
May 5, 2003 03:28 PM
