90 civic front end suspension repair
in order to pass my PA safety inspection, the shop says i need to fix my suspension. the guy is telling me the parts will be 900$, so of course i came home today to check ebay first. i just wanted to check with you guys and see if the parts he wrote down compare to the ones i'm finding on ebay.
he says i need:
both front tie rods outer
L/F upper ball joint
both rear trailing arms
both front low control arms
now what i'm finding on ebay are more along the lines of this:
1988-1991 HONDA CIVIC Front End Kit
Included in the kit:
2 - Upper Control Arms (Left and Right)
2 - Lower Ball Joints
2 - Outer Tie Rod Ends
2 - Inner Tie Rod Ends
2 - Front Sway Bar Links
this is a set i found for 102$-127$.
when i searched for some of the parts the mechanic listed, i didn't get any results (like the low control arms vs. the upper control arms). i emailed the seller of this set, but i thought i would ask you guys as well.
thanks!!!
he says i need:
thanks!!!
SpeedSin
17
Oct 31, 2008 12:54 PM
Steri
14
Feb 5, 2007 11:39 AM
LoooseGSR
Mar 5, 2004 10:54 AM
