motor question
Old Jun 25, 2008 | 07:22 PM
biggjerryc's Avatar
Default motor question
So, single cam y8. Before i get a stage 2 cam.. anything i should know? any unreliability? alot of stuff is getting replaced at that time.( timing belt, water pump, head gasket and studs, valve springs+retainers, port and polish, VAFC) I just want to know if itll be ok for a daily driver with all that stuff.
Old Jun 25, 2008 | 07:29 PM
ivan93egreppin210's Avatar
Default Re: motor question (biggjerryc)
everything sounds good except for the vafc. the vafc will trick your ecu into changing your fuel but does nothing for ignition. i suggest if you want to get the most out of this setup, you need an adjustable cam gear and a chipped ecu for tuning. maybey a slight mill of the head to bump compression but that is something you need to search. good luck.
Old Jun 25, 2008 | 09:58 PM
raidacaipo's Avatar
wait ur getting port and polished and stage 2 cams and etc.. etc???? all that money on a single cam vtec?? I say you just buy a b16 and call it a day.. youll get way more power in stock form then modifying the d16y8.. and would be a better daily driver then a modified d16y8.. matter of fact if ur on a budget I say get a b18b or b20b motor..
Old Jun 26, 2008 | 08:12 PM
biggjerryc's Avatar
Default Re: motor question (raidacaipo)
i was looking for an eg shell cuz i have a b20 block. i figured id work from there but now. my car got stolen today so i have some other decisions.
Old Jun 27, 2008 | 01:09 AM
raidacaipo's Avatar
wow that really sucks man.. hope you find it.. LETS KILL ALL THIEVES!!
OnlytheEnergy
Jun 12, 2010 02:40 PM
nation
May 11, 2008 07:47 PM
Crx_Civic
Feb 9, 2008 10:19 AM
DOHClessEF-9
10
May 14, 2005 06:11 PM
.Kevin.
Dec 21, 2004 03:17 PM
