Type r Suspension (beyond frustrated) - PLEASE HELP
Old Jun 25, 2008 | 06:59 PM
NashDishesDimes's Avatar
Default Type r Suspension (beyond frustrated) - PLEASE HELP
Ok i baught type r suspension for my 05 type s. i took it home and figured 3 hours and i would have the fu***rs on. 3 hours later i dont even have the right front coilover off. I took off every single mother F****ing bolt. Then i came to these tie rods, i un did the nut and the coilover wouldnt pull off. So i started hammering the **** out of it (didnt work). Then i went to the store and baught those tools with the claws and the bolt that screws upward in the center to pull it apart. Then i realized the tool has a point on it so all it did was put a hole in the bottom of the screw on the tie rod. So now im sitting here coming to you guys because i know just about everyone on here has aftermarket suspension so you have all done it. How do you take these tie rods off??? If you choose to help me please choose your words carefully because i dont know if i can handle reading another unclear description online. PLEASE HELP for i cannot handle any more frustration!!!!!!
Old Jun 25, 2008 | 07:53 PM
simonEp3's Avatar
Default Re: Type r Suspension (beyond frustrated) - PLEASE HELP (NashDishesDimes)
If you have a ball joint separator you can wedge in there and tap it with a hammer it should work. If not try turning the strut assembly as if you were turning in you car and try to wiggle it loose as you tap the ball joint separator in there. Goodluck bro.... it's always the easy things that are so frustratingly difficult.
Old Jun 26, 2008 | 05:31 PM
WhiteOnRice's Avatar
I use a pitman arm puller I rented/bought from autozone and a 4 foot pipe/breaker bar for ball joint and tie rods. I grinded the tip off so it doesn't dig into the bolt and dremeled the hell out of the inner walls to fit over our wide LCAs to seperate lower ***** joints.
Out of 4 lower ball joints I removed only 1 was still usable. I share your frustration.
Old Jun 26, 2008 | 09:36 PM
Brice.Hayden's Avatar
Default Re: (WhiteOnRice)
I did the same thing, gotall the bolts off and tried to take off the tie rod by banging the bottom with a hammer. All i did was smash the threads and was unable to re thread the bolt. had to get a brand new one. needless to say i'm going to have someone do it for me. I've done preludes, civics, integras and those are all cake, damn you RSX!!!!
Old Jun 28, 2008 | 05:20 PM
skuded's Avatar
its not that hard, just take a 5lb sledge and hit the arm that holds the tie rod end right where the end goes into the arm, dont hit the boot, or the bolt, hit the part that the tie rod is slid into, oh and good luck on the ball joints, yea when i did my clutch on the ground, i gave up using a hammer and just took the whole control arm out of the subframe
Old Jun 29, 2008 | 10:58 AM
Default Re: (skuded)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skuded &raquo;</TD></TR><TR><TD CLASS="quote">i gave up using a hammer and just took the whole control arm out of the subframe</TD></TR></TABLE>
Wow, I would have tried a proper tool before touching my subframe (one of the many types of ball joint seperators).
Old Jun 29, 2008 | 02:33 PM
FrankinDC5's Avatar
You can use one of these
http://forums.clubrsx.com/atta...04664
http://i21.photobucket.com/alb...i.jpg
There's also a video for the hammer route, I'll see if I can find it
Old Jun 30, 2008 | 05:43 PM
skuded's Avatar
uh white on rice, in case you didnt know, you have to remove the subframe to remove the transmission. which is involved in replacing the clutch, and i know about proper tools, i have about 15 k worth of tools, however they stay at work so i had to work with what i had
Adnan5224
Suspension & Brakes
Aug 11, 2009 08:20 PM
NAturalDC2
Suspension & Brakes
Mar 29, 2005 06:35 PM
nargenar
Dec 14, 2002 08:16 PM
EL-Driver
Apr 13, 2002 02:41 PM
