1998 ACcord. Check engine light on OBD port has no commucation
Old Jun 25, 2008 | 06:27 PM
Din's Avatar
Din
Default 1998 ACcord. Check engine light on OBD port has no commucation
Any other way i can find out what the problem is? Or how I can get the port to work again?
the problem on the car is the idle is all jumpy.
Old Jun 26, 2008 | 07:45 AM
99accordFX's Avatar
Default Re: 1998 ACcord. Check engine light on OBD port has no commucation (Din)
Get a test light and see if you have power to the DLC Port. IF not, you need to check all your fuses usually is the case. If you have power with no communication might need a new PCM but before going that far into it, Try another scan tool just to see if the one you are using is having problems with your application.
kenchidi
Transmission & Drivetrain
Dec 22, 2014 02:14 AM
f20bHavoc
Dec 24, 2012 06:14 PM
bbyron
Feb 18, 2008 09:43 AM
Spartoons
Jul 9, 2007 05:44 PM
Desired_Speeds
Jan 27, 2006 07:02 PM
