Rebuild my lsvtec monster or go k
Old Jun 25, 2008 | 06:01 PM
k20coupe's Avatar
Default Rebuild my lsvtec monster or go k
last year i blew my lsvtec and Im debating on whether rebuild it or drop a k in my crx
Old Jun 25, 2008 | 06:13 PM
b20beast83's Avatar
Default Re: Rebuild my lsvtec monster or go k (k20coupe)
B20 VTEC
Old Jun 25, 2008 | 06:15 PM
k20coupe's Avatar
Default Re: Rebuild my lsvtec monster or go k (b20beast83)
the ls vtec made 251 all motor on a dyno jet
Old Jun 25, 2008 | 06:16 PM
onepoint6i's Avatar
Go K
Old Jun 25, 2008 | 06:19 PM
k20coupe's Avatar
Default Re: (onepoint6i)
I want to but I have all the parts for the ls vtec all I have is an extra k20 shortblock
Old Jun 25, 2008 | 06:28 PM
onepoint6i's Avatar
Default Re: (k20coupe)
i see, its all personal preference and how far your pockets will go then
Old Jun 25, 2008 | 06:33 PM
UncleD's Avatar
If you have the $$, it's a no brainer. End of story. K.
Old Jun 25, 2008 | 06:53 PM
k20coupe's Avatar
Default Re: (clean rice)
I have the money to rebuild my lsvtec but I can sell my all motor setup and buy the rest of the parts I need for a k20 build but it will be a mild build not a fully build
Old Jun 25, 2008 | 07:17 PM
mar778c's Avatar
Community Builder
Community Influencer
What are the circumstances behind it blowing up? 250whp is a lot for any b-series.
I know people say k but 250 whp from a stock crank k20 is no walk in the park either.
What did you have in the lsvtec?
Old Jun 25, 2008 | 07:58 PM
k20coupe's Avatar
Default Re: Rebuild my lsvtec monster or go k (mar778c)
b18a1 86mm rs sleeved
custom wiseco 13.7cr
rpm rods
balanced blueprinted polished crank
b16 head p&p it flows 295 or 290 I think
bc specV cams bc valves springs and retainers
jg header 2.5 collector
hybrid AEM CAI
blox IM open and ported by blueprint
all the MSD ignition plugs blaster coil and box
tuned on crome
100 oct
Old Jun 25, 2008 | 08:01 PM
k20coupe's Avatar
oil starvation was the cause I want to switch the header a smaller cam and a new head for a new port blueprint say that they can make it flow over 300cfms
Old Jun 25, 2008 | 08:02 PM
k20coupe's Avatar
250 in a k is easy on a dynopack
2fastGSR's Avatar
King of the One Liners
250 isnt a whole lot for that build. Especially at 86mm.
Sell everything, buy k24 stock bottom end, use a k20 head with some decent cams , rbc and header.
thats what i would do
Old Jun 25, 2008 | 08:05 PM
k20coupe's Avatar
Default Re: Rebuild my lsvtec monster or go k (2fastGSR)
I want to make 270 so I can either rebuild the lsvtec with a better head cams and header or do a k24 and do a mild build 270 on a k is not easy to make and Im colser to hit that number on a b than k
Old Jun 25, 2008 | 08:09 PM
2fastGSR's Avatar
i'd have to disagree.
270 can be done on a stock k24 bottom end pretty easily. You just need the right parts.
You can hit 270 with that B bottom end as well, but you are correct the head/cams will need to change.
You can hit up Import Sports , they have a sick all motor b series build that makes more power than most b series builds
Old Jun 25, 2008 | 08:12 PM
k20coupe's Avatar
no way it can be done on a stock bottom end with 10.5cr tsx pistons
Old Jun 25, 2008 | 08:40 PM
k20coupe's Avatar
I will like to see a stock bottom end k24a2 or k24a1 whit a k20 head and some cams the
most I seen is 240 but mad torque
Old Jun 26, 2008 | 04:25 PM
k20coupe's Avatar
well I spoke with jeff from blueprint he said that they can work with my head and make it flow 320cfms I got the header now should I stay with specV cams or switch it ?
I think with a better port I can make the 270 on the b series
should I run 550cc or stay with the 440cc?
Old Jun 26, 2008 | 04:34 PM
DonF's Avatar
That will be the best B head ever. I would go with that. What class is this race car in?
Old Jun 26, 2008 | 04:35 PM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20coupe &raquo;</TD></TR><TR><TD CLASS="quote">b18a1 86mm rs sleeved
rpm rods
hybrid AEM CAI
tuned on crome
100 oct</TD></TR></TABLE>
You can definitely make 270 with that type of build. Get a VictorX IM and a custom header and you'll be right there.
Old Jun 26, 2008 | 04:49 PM
k20coupe's Avatar
I got a hytech replica I want to see if it will work
Old Jun 26, 2008 | 04:50 PM
k20coupe's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">That will be the best B head ever. I would go with that. What class is this race car in?</TD></TR></TABLE>
street class
Old Jun 26, 2008 | 04:51 PM
k20coupe's Avatar
made 240miles on a full tank
Old Jun 26, 2008 | 04:58 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">
You can definitely make 270 with that type of build. Get a VictorX IM and a custom header and you'll be right there.</TD></TR></TABLE> Damn, I did not know it was that easy, need to go back to work. Is his the same as your 270 build?
Old Jun 26, 2008 | 05:00 PM
k20coupe's Avatar
Default Re: Rebuild my lsvtec monster or go k (DonF)
if ur talking about the 270 all motor in the club rsx forums its not the same thats a k24/k20 build for my rsx this is the b series 270 goal
