HELP!!! HAVING MAJOR PROBLEMS W/ FRONT CAMBER KIT ON MY EM1
OKAY, I HAVE A LOWERED EM1 W/ A SKUNK2 PRO SERIES FRONT CAMBER KIT(ADJUSTMENT IS A SLIDING BALL JOINT) I'VE HAD IT FOR AWHILE...NEVER HAD NO PROBLEMS W/ IT UNTIL KNOW.....THE BALL JOINT KEEPS MOVING THEREFORE MAKING MY LF WHEEL CAMBER IN.....I'VE ALREADY REPLACED THE BOLTS THAT HOLDS DOWN THE BALL JOINT....BUT THAT DIDN'T WORK....HAS ANYBODY OUT THERE EXPERIENCED SIMILAR PROBLEMS??? OR DOES ANYBODY HAVE ANY IDEAS ON WHAT I CAN DO TO KEEP IT FROM SLIDING????
HELP!!!!!
HELP!!!!!
yup just do what i did... take off the camber kit and assuming you can see the marks on the control arm from where the camber was set to just set ur ball joint there, and loc-tite ur bolts, let it dry, re-install, and BLAMMMMMMMM ur done.... i had this happen to me too, only 3 of the bolts fell out and the 4th one was barely hangin in there... after i replaced the bolts and did loc-tite had NO issues whatsoever...!!
OKAY I SEE HOW THAT WOULD WORK BUT SEE THE BOLTS ARE TIGHT AS CAN BE, THERE NOT LOOSE OR BECOME LOOSE. IT JUST KEEPS SLIDING.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flaco si »</TD></TR><TR><TD CLASS="quote">OKAY I SEE HOW THAT WOULD WORK BUT SEE THE BOLTS ARE TIGHT AS CAN BE, THERE NOT LOOSE OR BECOME LOOSE. IT JUST KEEPS SLIDING.</TD></TR></TABLE>
Hmmm, well i used 2 washers under each bolt before they touched the control arm itself... Could you send some pictures of your current setup?
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
you need to use star washers, loc tite, and torque to 10 foot lbs. i had this problem 9 years ago, and fixed it using the above. good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">you need to use star washers, loc tite, and torque to 10 foot lbs. i had this problem 9 years ago, and fixed it using the above. good luck.</TD></TR></TABLE>
star washers i'd say are optional.. and assuming he has a torque wrench... i used a simple 1/8" plate washer, loc-tite, an just tighted the **** out of them with my allen key... over 2 years, had no problems...
flaco si
Suspension & Brakes
Jun 26, 2008 07:53 AM
iLOVEthatEMone
14
Jun 28, 2007 01:52 PM
iLOVEthatEMone
Suspension & Brakes
Jun 25, 2007 11:55 AM
