Toda A's VS 00' ITR cams
Old Jul 18, 2002 | 10:41 AM
Doctor CorteZ's Avatar
Default Toda A's VS 00' ITR cams
on stock valvetrain is it worth it for Toda's ?
what about T-belt is stock ok for these cams?
is STOCK valvetrain ok with these?
any idea on power gains over the ITR cams?
this would be with CTR pistons and stock ITR valvetrain, port polished head , cam gears , STOCK injectors and VAFC with a FPR
any insight ? pros / cons ?
I'm looking for midrange , this car see the track alot and IS NOT a drag car
THANKS - Jamie
Old Jul 18, 2002 | 10:44 AM
Reid's Avatar
Global Moderator
Default Re: Toda A's VS 00' ITR cams (Doctor CorteZ)
Toda A's are fine with stock ITR valvetrain.
I would definitely go with them over ITR cams, if you want a mild cam upgrade.
Tuning is still the key though.
Old Jul 18, 2002 | 10:45 AM
Default Re: Toda A's VS 00' ITR cams (Reid)
they will be DYNO tuned , ALOT
Old Jul 18, 2002 | 10:46 AM
Johnny Tran's Avatar
go with Crane.......mAAAd t0p end
and P.S. im mailing in your entry for "full custom crazy maxeed" at hot import nightz.
nick, who doesnt think camz will earn jamie any "show pointz"
Old Jul 18, 2002 | 10:48 AM
Reid's Avatar
Global Moderator
Sounds good.
Go with the Spec A's and show us the dynoplots later.
Old Jul 18, 2002 | 10:55 AM
motor wont be finished for awhile
HPDE's and wear items are killing my wallet, but soon.....SOON
Old Jul 18, 2002 | 10:57 AM
oh yeah , is STOCK belt OK ?
any other concerns on OEM parts with the A's ??
Old Jul 18, 2002 | 10:58 AM
Reid's Avatar
Global Moderator
Being that the lift isn't much greater than stock and a stock ITR valvetrain can be utilized I'd say you can use a stock timing belt.
But also, how much is a Power Enterprise belt going for these days? I'd pay a few hundred dollars for piece of mind.
Old Jul 18, 2002 | 11:04 AM
BlueR's Avatar
PE timing belt can be had for ~160 shipped...i'd put one on
Old Jul 18, 2002 | 11:20 AM
B18CXr's Avatar
Default Re: Toda A's VS 00' ITR cams (BlueR)
you need gears and that's it
stock belt is fine
Old Jul 18, 2002 | 11:22 AM
sgT's Avatar
sgT
Stock belt is fine. I would recommend a set of intake valvesprings for the exhaust
side but thats about it.
Old Jul 18, 2002 | 11:51 AM
rainmanEK's Avatar
big strong guy
Default Re: Toda A's VS 00' ITR cams (sgT)
Have you considered the skunk2 stage 1 cam? very similer in duration and lift to the toda a!
little cheaper also! eric
Old Jul 19, 2002 | 05:15 AM
Steve , I NEED to talk to you about this when I come down next week
Old Jul 19, 2002 | 06:28 AM
nsx-Animal's Avatar
Stock internals are fine as long as you don't raise the stock rev limiter. Stock belt is ok also. This is the way I am running them.
-Frank
Old Jul 19, 2002 | 07:01 AM
Default Re: Toda A's VS 00' ITR cams (rainmanEK)
i dont care much for Junk2 - but thanks anyway
Old Jul 19, 2002 | 08:59 AM
Asahi's Avatar
This brings me to a question I have had.
What rev limit CAN the sptock valvetrain handle
AND
Would the 00/01 Stock ITR cams make any power above 8500 (asuming the springs can handle it)?
Edit: make power with intake, header, a/f controler and cam gears . . . Need compression??
[Modified by Asahi, 12:00 PM 7/19/2002]
Old Jul 19, 2002 | 09:47 AM
Default Re: Toda A's VS 00' ITR cams (Asahi)
I would like to know also
Steve ?
Old Jul 19, 2002 | 09:57 AM
Reid's Avatar
Global Moderator
Stock ITR valvetrain is good to 9100 rpm.
Stock cams make power to 9100 rpm.
Old Jul 19, 2002 | 09:58 AM
Asahi's Avatar
At stock compression? Unmodified or with bolt ons?
Any concerns in bumping redline/fuel cut to 8900-9000?
Old Jul 19, 2002 | 10:03 AM
HybridKOOP's Avatar
I disagree about making power to 9100. My dyno plot, as well as most other stock ITR internal'd dynos show power falloff beginning at about 7800.
Old Jul 19, 2002 | 10:05 AM
Asahi's Avatar
Default Re: Toda A's VS 00' ITR cams (HybridKOOP)
Hence why I asked about stock compresion. One might argue that those are the peak numbers for the cams highly modified.
Needs clarification.
Old Jul 19, 2002 | 10:09 AM
TaboR's Avatar
New User
if i have the money to spend on Toda A, i rather save up to get at least some B's
with completely valve train swap~!
HybridKOOP's Avatar
Even with more compression, better gas, better ECU, better whatever... I do not believe the grind of a stock ITR cam will make continuous power past 8000... if someone has a plot that shows otherwise, I'd like to see it.
Old Jul 19, 2002 | 10:10 AM
Reid's Avatar
Global Moderator
Stock compression.
Bolt-ons would be nice.
No concerns.
Old Jul 19, 2002 | 10:12 AM
Reid's Avatar
Global Moderator
It does.
Sorry, all my links to pics of dynoplots aren't working anymore.
Robbie, Esteban, etc feel free to jump in with dynoplots.
