leak down test- integra smoking..
Old Jun 25, 2008 | 06:50 AM
90teg91hatch's Avatar
Default leak down test- integra smoking..
my integra smokes only when i get on it... and i know i need a valve adjustment b/c it sounds like a tractor... so my question is if i did a valve adjustment do you think it may solve this problem being if pistons are bad and whatever else... i know a leak down test will tell me a lot on why my car is smoking but i have the tools to do the valve adjustment and i was reading about the leak down test not entirely sure on how to do it, but i will just read some more on it and will figure it out... so the question is if i do a valve adjustment do you think it might take care of some smoke? or does that have nothing to do with it smoking at all?
Old Jun 25, 2008 | 11:12 AM
spidy3's Avatar
Default Re: leak down test- integra smoking.. (90teg91hatch)
probably wont do much for the smoking. do you have to add oil between oil changes? Do a compression test and see if any are lower specs, check your spark plugs for white chunks (oil consumption) and one or more cylinders are low add a cap full of oil down into it and check compression again. if its a decent amount higher then your rings are shot on that cyl.
Im newer to hondas but I've been told by alot of people that when you hit vtec you burn a little oil anyways so maybe thats just reason for it smoking.
Old Jun 25, 2008 | 03:46 PM
Default Re: leak down test- integra smoking.. (spidy3)
nope no vtec on this car.. i wish though... ha... ummm yes i do have to add oil between oil changes a lot of oil.. haha.. ummm i can put oil in it a little more then half on the mark where it should be and in 7 days... no oil will read on the stick... ahha its bad... so it pretty much has fresh oil in it all the time... i just keep using the walmart cheap oil for 8 dollars... i tried the no smoke treatment stuff and it seems to last a little longer like 10 days but for the price of that treatment its just worth buying the oil over and over...
parkerjamison
Sep 11, 2008 07:32 PM
drummr6
Jan 3, 2008 07:26 PM
iBrandon
Jul 31, 2006 08:03 AM
Dropped90Integra
Apr 10, 2005 06:38 PM
Renegade
Aug 31, 2004 10:25 AM
