FS: 1995 Integra B18B1 1.8L OBD1 Complete Engine - Eastern PA
SOLD
Located one hour north of Philadelphia in the Lehigh Valley area
Up for sale is a 1995 Acura Integra LS 1.8L B18B1 OBD1 Non-VTEC engine. It comes complete with intake and exhaust manifolds, throttle body, accessories, distributor, alternator, a/c compressor, clutch, flywheel etc. It does not come with the starter or the alternator belt however. All that would be needed for a swap is axles, mounts, ECU, shift linkage, starter, transmission, alternator belt. It runs strong, does not smoke, and is very quiet - no noises. This is an OBD1 engine with around 115k miles, it was pulled from a 1995 Integra LS that the engine was swapped out for an H22 engine/trans. I believe I have a few stock Integra mounts laying around that can be included and used if you're swapping this into a 1992-1995 Honda Civic or Del Sol.
Modified by ProMotive at 7:35 AM 7/15/2008
