pioneer problem in 95 coupe
Old Jun 25, 2008 | 04:56 AM
TehMan's Avatar
Default pioneer problem in 95 coupe
pioneer problem in a 95 coupe
its a DEH-P4900IB i guess...thats what the tag says...i put it in one day and didn't plug up the big black antenna wire and for some reason it wouldn't cut on...no power at all going to the cd player...so then i plugged the wire in and it worked...well last night i pulled the antenna thing off and put a block off on the antenna hole because i never listen to the radio...and now the cd player won't work anymore...so i went to pull the cd player out of the car to check why it wouldn't work and the wire like ripped out of the end of the plug...
so i guess the question is...does that wire have anything to do with the power to the cd player?
Old Jun 25, 2008 | 05:07 AM
Nbboy7's Avatar
sound like you have a bad ground on the radio. It work when the antenna pluged in. If it did the antenna was providing a good groud. Wires get riped out is bad and could cause a short
Old Jun 25, 2008 | 05:34 AM
TehMan's Avatar
Default Re: (Nbboy7)
i didn't think that big antenna wire would have to work...i checked the harness and everything is wired fine...i'll try to find a way to fix that big antenna wire and plug it back up
Old Jun 25, 2008 | 05:39 AM
Nbboy7's Avatar
The cd player should work with out the antenna being pluged in
Old Jun 25, 2008 | 05:44 AM
TehMan's Avatar
thats the only thing that isn't plugged up...
Old Jun 25, 2008 | 06:00 AM
Nbboy7's Avatar
Just to run a ground test tap into the black wire on the back of the radio and put it to the bare metal of the car and see if it turns on
Old Jun 25, 2008 | 06:14 AM
TehMan's Avatar
will do
TehMan
Audio / Security / Video
Jun 26, 2008 07:16 AM
Manolo
May 15, 2006 02:25 PM
ineedmoney
Jun 3, 2004 10:30 PM
CRX7
Oct 3, 2003 06:59 AM
