Need some pointers on changing my alternator on my 91 DA
Need some pointers on changing my alternator on my 91 DA it's my first time doing this so if you can help me i'll appreciate it thanks
removing the drivers side axle makes the job 20 times easier ..it might even be the only way actually
but its pretty straight forward just make sure you tension it right or else it will make noise..or slip and could cause your car to die due it not charging properly
