Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
ebay fogs!
Old Jun 24, 2008 | 06:09 PM
DynastyRacer22's Avatar
Default ebay fogs!
ok so i already checked the faq area and the links on how to install ebay fogs are down..anybody wanna repost it? id apreciate it thanks!
Old Jun 25, 2008 | 06:24 AM
Harlowe's Avatar
Function>Fashion
What do you need help with? Cutting the bumper, or the wiring?
Old Jun 25, 2008 | 07:09 AM
agati's Avatar
Default Re: (Harlowe)
i ordered ebay fogs too! im just waiting for them to be on my doorstep anyday now. i'm a little confused about how to cut the bumper too but i have an old bumper from when i smashed my front end before so im going to practice on that first haaha! but for the instructions go to http://www.handa-accessories.com/civext01.html and down the page a little they sell the fog lights. And they have a complete guide in how to do it. hope i helped!
Old Jun 25, 2008 | 08:21 AM
05civicdriver's Avatar
Default Re: (agati)
you can even get the instructions on the FAQ section if u searched for it. I had trouble doin the wiring sicne it was my first time but i gave up and just had someone wire it for me. i did the mounting instead tho. the cutting was easy and as well as the drilling. that step actually took like 15 minutes only.
Old Jun 25, 2008 | 09:41 AM
yea i already got it all mounted i just need the wiring information i already looked in the faq https://honda-tech.com/zerothread/2058317 and the links on how to install ebay fogs is down i got the handaacessories one already its a lil diffrent since mines not oem lol but once awang will email it to me i'll host it for everyone to use as well..thanks guys!
Old Jun 25, 2008 | 12:28 PM
Default Re: (DynastyRacer22)
i got the ebay foggies too. the only thing is..the switch is too big for the lil hole on the center console. mines actually stickin out but its all good...i like it.
Old Jun 25, 2008 | 03:17 PM
Default Re: (05civicdriver)
did the shop that installed it for you ran into any problems with the harness or any modifying needed or anything? and also did they just followed the oem instruction? because im thinking about letting a shop install it for me as well lol
Old Jun 25, 2008 | 03:36 PM
i hav no idea wat the shop did.. i gave em wat i had in the box after i mounted the lights and a few minutes later, the lights were workin. i dont know where they put the harness and the wiring thru but they made it work.
Old Jun 25, 2008 | 04:36 PM
homelessEm2's Avatar
ill be honest guys half those ebay harnesses are even worthy of installing. i jus wired mine into the stock running low beams on my 04 and called it a day. its been months now and not a single problem. simple...maybe like 20 mins to wire up that way and legit
Old Jun 25, 2008 | 06:45 PM
Default Re: (homelessEm2)
if i knew as much as u do about cars i wouldve done the same but i dont. lol. but i like the convenience of being able to turn of the fogs whenvr i like...
Old Jun 25, 2008 | 07:00 PM
BRIANP's Avatar
mine should also be here at the end of this week i will take some pics of the install when i get time to do it.
Old Jun 25, 2008 | 08:09 PM
lol i attempted to install it an hour ago and...i suck there wer too many connectors and my harness look nothing like the diagram from honda..i also accidently unpluged my srs connector that was mounted on the front support would my air bag pop when i start the car?
Old Jun 25, 2008 | 08:22 PM
BakktoJDM's Avatar
A friend and I figured out the junk ebay harnesses and switch, verrrryyy confusing and custom work is required. THere is one set of wires you dont need is all i can remember
Old Jun 25, 2008 | 08:33 PM
Default Re: (BakktoJDM)
ok so i took this pic of the diagram that came with the ebay fogs..the one i circled in red, where does that plug into? lol it look like all of it is suposed to be attatched but in the honda diagram it shows this:
from the fog harness its suposed to be pluged into the factory car harness i assume? but i didnt find any plugs available there besides the one on the passenger side that had blue tape around it.. ive searched on google and nothing to be found
Old Jun 25, 2008 | 10:40 PM
01_civic's Avatar
this was not a bad DIY at all. it did take me a while to figure out all the wiring because i was new to wires and installing fogs. started at around 6 and finished all the wiring at 8 (kinda slow but i got everything to work) then need to cut bumper tm and bam...im DONE!
Old Jun 25, 2008 | 11:32 PM
j023's Avatar
i remember my 1st attempt at fogs! the wiring on ebay's are different or at least the crap ones I got, had to switch some stuff around in order to work. Now they work fine
Old Jun 26, 2008 | 04:02 PM
GeNeRic BizZ's Avatar
Any pics? I'm thinking about getting fogs for my car as well.
Old Jun 28, 2008 | 03:09 PM
Default Re: (GeNeRic BizZ)
go to the picture thread. theres tonnes of pix with fogs.
heres mine
Far shot of car with skirts and fogs.
Old Jun 28, 2008 | 08:15 PM
noss88's Avatar
i bought the ebay kit too for 01-03, does anybody have or know how to cut the bumper? the faq is for 04-05
Old Jun 28, 2008 | 11:34 PM
01_civic's Avatar
Default Re: (noss88)
i just eye'd it from the DIY instructions and it came out fine. just make sure you have some good tools for cutting like a dremel.i just used random tools because i didnt have one so it took longer. after you get used to it, the other side is simple. and the wiring is easy once you decide how u want to wire it, either from left or right.
Old Jul 1, 2008 | 12:11 PM
Spoon EM2's Avatar
Default Re: (01_civic)
i got some from ebay me and my friend had a lil problem at first wit the wireing and my is an 03 which the bumper is slighly harder to cut out but besides that it was fine the wiring need a lil mod but not to hard ill see if i can still find the guild i had if not use the 04-05 one its the same as 01-03 just the bumper cutout is different
Old Jul 1, 2008 | 02:27 PM
lilmike's Avatar
i found this on civicforums
http://www.civicforums.com/for....html
Old Jul 2, 2008 | 02:19 PM
D17alltheway's Avatar
Default Re: (lilmike)
That is a good write up and i follow the directions but im stump on which slot to plug the ebay harness into the car harness
Old Jul 2, 2008 | 10:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilmike &raquo;</TD></TR><TR><TD CLASS="quote">i found this on civicforums
http://www.civicforums.com/for....html</TD></TR></TABLE>
finally somethin that works..thanks dude i think that link you posted should also be in FAQ.
Old Jul 3, 2008 | 12:24 AM
Spoon EM2's Avatar
Default Re: (D17alltheway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D17alltheway &raquo;</TD></TR><TR><TD CLASS="quote">That is a good write up and i follow the directions but im stump on which slot to plug the ebay harness into the car harness </TD></TR></TABLE>
u if u look under there is one that is a single on that ut plugs into its on the top next the the 2 or 3 pin one ill try to find a pik for u or ill take a pik
