96 acura integra Integra Clutch Problem
Old Jun 24, 2008 | 02:37 PM
fastfwd's Avatar
Default 96 acura integra Integra Clutch Problem
I got a 96 acura integra from my brother and the clutch activates and works fine. The problem is that the clutch pedal doesn't come up. After I take my foot off the clutch it can still be pulled about a 1/2 inch higher. The clutch was changed in the car and I already bled the clutch. (I didn't do the work) so I bled it again after I got the car. I noticed it has a bolt with a nut on the back of the pedal and it was finger loose. I can spin it up or down easily. Should this be tight? I mean the car runs great I was just wondering how to fix this. Could it be the slave cylinder going bad? I don't see any fluid inside the car under pedal or further up.
Thanks
Josh
Old Jun 25, 2008 | 02:39 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 96 acura integra Integra Clutch Problem (fastfwd)
The clutch pedal is adjustable. Does it catch right off of the floor?
Old Jun 25, 2008 | 04:45 PM
fastfwd's Avatar
Default Re: 96 acura integra Integra Clutch Problem (Dogginator)
I'm not sure what you mean. I'm guessing that bolt is for adjusting it. I'll try that. The clutch does grab fine though. Like any other car I've driven.
Old Jun 25, 2008 | 05:26 PM
Dogginator's Avatar
Daisy... Daisy...
It could be the switch for the clutch pedal switch (part 18).
http://www.acuraoemparts.com/d...ch=no
jfral087
Apr 10, 2012 08:37 AM
acura1652
Feb 27, 2012 08:14 AM
TimKing89
Transmission & Drivetrain
Aug 12, 2010 10:32 AM
awall
Jun 2, 2002 02:45 PM
