p28 on built ls vtec what ecu do I go with
Old Jun 24, 2008 | 10:24 AM
Silverbullet114's Avatar
Default p28 on built ls vtec what ecu do I go with
My friend told me to get a skunk 2 chip, but since my peak boost turbo kit should be coming in this week I dont know what to do. He said get the chip and get it tuned on hondata. I dont undestand I want vtec to open up earlier because right now it opens at 5200. Any suggestions I got cp pistons and eagle rods
If I get hondata can the tuner adjust when vtec opens and can I use it on my laptop and what hondata to I buy thanks...
Old Jun 24, 2008 | 11:09 AM
98vtec's Avatar
moderator emeritus
Default Re: p28 on built ls vtec what ecu do I go with (Silverbullet114)
the tuner can do everything with hondata.
http://www.hondata.com
start reading
chips are garbage and you can now proceed to slap your friend.
don't worry about vtec. The tuner will put it where the ENGINE wants it. Not where YOU want it.
Old Jun 24, 2008 | 11:28 AM
thanks alot for the info, but what hondata system do I go with and with it be funcitonal on my laptop or only for the tuner thanks alot
Old Jun 24, 2008 | 11:32 AM
98vtec's Avatar
moderator emeritus
Default Re: (Silverbullet114)
i would go with s300 if you are stuck on just wanting hondata.
Old Jun 24, 2008 | 02:31 PM
93turbo16's Avatar
Default Re: (98vtec)
If you go hondata, definitely get the S300 system.
But I would get in contact with the tuner that is going to tune your car and ask them what they suggest and are comfortable using.
Old Jun 25, 2008 | 10:18 AM
G2IntegraGS's Avatar
Whats wrong with s100? Is it okay for a very mild NA setup?
Old Jun 25, 2008 | 11:29 AM
93turbo16's Avatar
Default Re: (G2IntegraGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2IntegraGS &raquo;</TD></TR><TR><TD CLASS="quote">Whats wrong with s100? Is it okay for a very mild NA setup?</TD></TR></TABLE>
You could go with it. But that is almost stone age technology now.
Roybal 3
Aug 22, 2008 01:56 PM
silvercivic_ex-t
Mar 8, 2005 06:08 PM
B18PoweredCivic
May 25, 2003 07:53 AM
avividmemory
Jan 20, 2003 04:52 PM
