WTB - Integra engine hoist brackets
I'm looking to buy the brackets that are bolted to the motor that you hook the engine hoist to, to lift the motor out. The motor is a 96 gsr. Looking for some one local in VA but if you have them and not local LMK, I might be down for shipping. thanks.
lets see a picture. i always just put a bolt thought the chain on the front of the tranny where the tourqe mount goes and then the hole behind the valve cover above the alternator.
I can't find a picture online. I can only find them in the Haynes manual. It is the tabs that are in front of the valve cover on the drivers side, and some where on the back side of the valve cover on the passenger side or tranny.
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
just use the power steering hole on the front of the head then there is a hole on the back of the head. i have a load leveler and i use the dizzy holes. never had a issue yet and have pulled plenty of motors. so i say do not waste your time
JENNY_EG6
Jan 16, 2009 10:29 AM
