type r climate control in LS
I'm pretty sure that the climate control is identical on all Integras which came from the factory with air conditioning - including the LS, GS-R, Special Edition, and '00-01 Type R.
However, the '97-98 Type R did not have air conditioning as a standard feature; it was a dealer-installed option. So if you're expecting A/C from a '97-98 Type R, you may or may not be getting it.
Modified by nsxtasy at 1:45 PM 6/24/2008
USDM ITR climate controls are plug and play, light up amber. 00-01 ITRs have the faux carbon fiber.
JDM ITR climate controls are plug and play only after you swap in the white USDM temperature select cable and remove the blue JDM one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">JDM ITR climate controls are plug and play only after you swap in the white USDM temperature select cable and remove the blue JDM one.</TD></TR></TABLE>
what?
i did none of this to my JDM climate control. please explain, with pics if you can..
what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JThrasher79 »</TD></TR><TR><TD CLASS="quote">
what?
i did none of this to my JDM climate control. please explain, with pics if you can..</TD></TR></TABLE>
I don't have pics. But the JDM cable is slightly shorter and routed on the other side of the temp select bracket.
what?
ok now i remember switching the cables. when i got mine the cable was just cut way short so i had to use my old one. thats why i didnt remember.
lazilude909
Jun 26, 2007 04:17 PM
