5 speed 97 civic
Old Jun 24, 2008 | 01:45 AM
1993-eg1's Avatar
Default 5 speed 97 civic
can i use pedals from a 95 ex in my 97 ex? i no most of the time no but y change them.
Old Jun 24, 2008 | 02:50 AM
1993-eg1's Avatar
Default Re: 5 speed 97 civic (1993-eg1)
well after a lot more goggling i fond this out
93 del sol si
BRACKET, PEDAL 46590-SR3-L31
BRACKET, CLUTCH PEDAL 46990-SR3-A00
PEDAL ASSY., BRAKE 46500-SR3-L10
97 civic ex 4 door
BRACKET, PEDAL 46590-S01-A30
PEDAL ASSY., BRAKE 46500-S04-A10
94 civic ex 4 door abs
so as you can see the clutch is the same on all cars so my new question has some one tried cutting the brake pedal on a auto the use it with a clutch or is the geometry different
Old Jun 24, 2008 | 11:30 AM
94EG8's Avatar
Seagull Management
The brake pedal for a manual is quite a bit different, it has a pretty serious bend to the right, the automatic pedal goes straight down, if you saw the 2 of them together it would make a lot more sense. I assume your swapping out an auto for a 5 speed, hope that goes well, its really not that hard of a swap, the biggest things are just removing/installing the pedals and the passenger's side pocket mount, one last thing, the throttle cables between the automatic and manual are different, either swap the entire pedal set and the cable or keep your old gas pedal and cable
Old Jun 24, 2008 | 02:38 PM
1993-eg1's Avatar
Default Re: (94EG8)
thack you i am doing a bit more then that i am putting in a h22 at the same time but all is pretty well so far i am have a lot of problems with the wiring tho
crazylooks83
Aug 8, 2010 04:17 PM
fastshift
Welding / Fabrication
21
Mar 6, 2008 09:58 AM
HONDRETTI
Nov 16, 2007 05:00 PM
quik89
12
Jan 18, 2007 11:00 PM
jdm206
12
Feb 21, 2006 03:22 PM
