Check valve problem
Old Jun 23, 2008 | 11:19 PM
3gcvcd16's Avatar
Default Check valve problem
I have an 84 civic with brand new integra master cylinder and brake booster, the car runs fine except when driven for a couple of miles the brakes gets stuck and do not release for atleast 20-30 minutes, by removing the check valve that is on the vacumm line that goes to the booster it releases the brakes and everything works perfect for a couple of miles more, the thing is that I test the check valve and it seems to be ok. What could be the problem?
Old Jun 25, 2008 | 09:55 AM
welfarepc's Avatar
sounds like your brake pedal is out of adjustment causing your MC/booster to clamp up your brakes
Cortez_h
Suspension & Brakes
Jun 12, 2010 02:49 PM
mikej94civex
May 11, 2010 08:39 PM
crazyboy
10
Sep 15, 2009 08:04 PM
duckmanEG
28
Sep 24, 2007 07:43 PM
85mm LS VTEC
Mar 31, 2007 07:57 PM
