looking in to obd conversions
Old Jun 23, 2008 | 04:57 PM
rickykline's Avatar
Default looking in to obd conversions
ive got a 91 crx hf i just got the car recently. its got a b18c1 block with a 00 b16 head and intake manifold. it has a pr3 obd0 ecu in it now. with obd0 distributor and obd0 injectors.i was wanting to know whether its worth it to swap to obd2 vs obd1.. i know i would have it much easy when it comes to diagnosing the car with obd2. i know id need to put a second o2 after the cat and i might need to install a fuel tank pressure sensor. but thats about all i know..im very knowledgeable with wiring. im ase master L1 tech. so im not new to cars at all. im just tired of the hideous wiring in my new toy.
Old Jun 23, 2008 | 06:27 PM
sgallagher's Avatar
Default Re: looking in to obd conversions (rickykline)
An OBD2 conversion is not a very common one and not very practical at that.
You can achieve much more tuning capaility by converting to OBD1 instead. Honda's obd system is quite good as far as diagnosis goes.
If its only the diagnosis on your engine you're worried about, don't, these engines are pretty basic.
Stick with OBD1.
Old Jun 23, 2008 | 07:46 PM
vtecb18c's Avatar
Default Re: looking in to obd conversions (sgallagher)
x2^...obd1 is very unrestricted where as it would just be stupid to go obd2
Old Jun 24, 2008 | 05:12 PM
White94Civic's Avatar
Default Re: looking in to obd conversions (vtecb18c)
should i got with the obd1 injectors or just the clips? also what kinda car would i get a obd1 b16 distributor from? can i put the obd plug on the obd1 distributor? just repin it what ecu is best? i dont want a check engine light on at all. i dont the motor has a knock sensor on it but i could be wrong. should i order a o2 sensor from the same car i get the dizzy from?
Old Jun 25, 2008 | 06:37 PM
rickykline's Avatar
bump
helldriver88
May 2, 2010 07:50 AM
Nick97hatch
Oct 10, 2004 10:56 AM
T_Rex
13
Nov 14, 2002 06:19 PM
twoquickls
May 21, 2002 08:35 PM
