B-series Cable to Hydraulic Transmission swap question.
Old Jun 23, 2008 | 02:34 PM
FOMULA91's Avatar
Default B-series Cable to Hydraulic Transmission swap question.
Found the D Series EF Civic and CRX Hydraulic Transmission Swap but cant find the B-series.
http://www.hondatuningmagazine....html
I was wondering how the VSS work for a B-series cable transmission set up with a OBD1 conversion. I know Hasport provide cable to hydro conversion kit but how would the cluster work if the wiring harness is converted to OBD1?
I appreciate for your help.
Old Jun 23, 2008 | 03:44 PM
downest's Avatar
Default Re: B-series Cable to Hydraulic Transmission swap question. (FOMULA91)
You can use any B or D series cable VSS sender, the signal to the ECU in our cars comes from the cluster.
Old Jun 23, 2008 | 09:18 PM
FOMULA91's Avatar
Default Re: B-series Cable to Hydraulic Transmission swap question. (downest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">You can use any B or D series cable VSS sender, the signal to the ECU in our cars comes from the cluster. </TD></TR></TABLE>
So u can use the cable VSS without pluging the electronic VSS and the OBDI ECU still reads the signal? Correct me if I'm wrong cuz I have people swap out cluster and ect.
Old Jun 24, 2008 | 07:30 AM
downest's Avatar
Yes, if you keep your stock cluster, keep your stock sender. The VSS signal will be read at the cluster and sent to the ECU from there. If you change to a newer cluster or a JDM one that uses electronic VSS, you need to run the three wires to the cluster and splice one into the ECU signal wire.
Old Jun 24, 2008 | 09:29 AM
FOMULA91's Avatar
Thanks!!! I was just tripping cuz some people told me to change cluster, get the cable to hydro conversion kit and ect....
Thanks for the help
Old Mar 22, 2010 | 05:38 PM
elegnasty's Avatar
TRIAL USER
wher can i find cable to hydro conversion kit?
h23vtecDA
May 24, 2011 07:15 PM
PayMecracka
Apr 10, 2011 07:59 AM
keko656
Aug 15, 2009 10:13 PM
FOMULA91
Jun 24, 2008 12:03 AM
rewerbcrx
Jul 19, 2007 04:28 PM
