Losing Brake Fluid
Old Jun 23, 2008 | 02:14 PM
stevew84's Avatar
Banned
Default Losing Brake Fluid
i have a 90 ef with a d15d2 stock engine. recently i have noticed that my brake light keeps coming on and the master cylinder is low, this happens once a day and i keep having to top it off with fluid.
obviously im losing fluid but i dont know where, there isnt any puddle under the tires and there isnt spray on the rims.
a few months ago i flushed out the brake system due to synthetic fluid seeping its way thru the caliper and leaking all over the place, then replacing with dot 3 fluid.
i havent had any problems until 3 days ago, but like i said there is no puddle or spay but its going somewhere. only thing i can think of is that its squirting out of one of the weep holes on either caliper or drum therefore not leaving a puddle when i park...only evacuating when i press the brake pedal.
any help would be appreciated.
thanks
Old Jun 23, 2008 | 04:08 PM
bobjohnson's Avatar
Default Re: Losing Brake Fluid (stevew84)
Turn the car on, pump the brake in the driveway a whole bunch of times. Check for puddles. Also check along the edge of your carpet for wet spots, one of the lines might have started leaking.
Old Jun 24, 2008 | 05:43 AM
stevew84's Avatar
Banned
got home and pumped the brakes for a few minutes. leaking from the passenger side caliper. i replaced the rubber seal on that piston a few months ago so that is probably whats wrong. but then again the weep hole could be loose somehow i didnt take off the tire yet.
Old Jun 24, 2008 | 06:14 AM
acmoc's Avatar
Default Re: (stevew84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevew84 &raquo;</TD></TR><TR><TD CLASS="quote">got home and pumped the brakes for a few minutes. leaking from the passenger side caliper. i replaced the rubber seal on that piston a few months ago so that is probably whats wrong. but then again the weep hole could be loose somehow i didnt take off the tire yet.</TD></TR></TABLE>
do it and check back with us
businessmanph
Feb 9, 2006 07:32 PM
david
Oct 31, 2005 11:02 AM
Balut
Feb 24, 2005 08:31 PM
Understeer
Nov 30, 2003 10:28 AM
Cosworth
24
May 22, 2002 07:49 AM
