Does an ECU have info on the cars VIN ?
Old Jun 23, 2008 | 12:38 PM
GoFastTshirts.com's Avatar
Default Does an ECU have info on the cars VIN ?
I have a car from japan that i am trying to get inspected and my mechanic is telling me that when he hooks the car the ecu tells dmv the VIN on the car is this true ?
Is it possible to hook up another car or will the DMV see that it is a different car?
This car would pass but the JDM ECU's can't communicate with USDM readers. It just says "error cannot communicate" when you hook up a scan tool to it.
I have searched and there is NO answer some say yes some say no does anyone one know for sure cause i need this car legal.
Thanks
Modified by GoFastTshirts.com at 5:02 PM 6/23/2008
Old Jun 23, 2008 | 12:43 PM
dividedas1's Avatar
Default Re: Does an ECU have info on the cars VIN ? (GoFastTshirts.com)
what kind of car? ob-0 or 1 i doubt it. im not too sure about ob-2
Old Jun 23, 2008 | 12:44 PM
It's a 1996 Honda Integra Type R from Japan. OBDII I believe.
Modified by GoFastTshirts.com at 5:01 PM 6/23/2008
Old Jun 23, 2008 | 02:22 PM
itsmejto's Avatar
if OBD2, then yes, the vin is stored in the ecu.
Old Jun 23, 2008 | 02:40 PM
sicones's Avatar
Default Re: Does an ECU have info on the cars VIN ? (itsmejto)
ok, ALL USDM OBD2 96-00 civic and integras do not store the VIN# in the ECU. This is a myth. (Some VERY new cars, however, do store VIN#, exactly what cars I don't know, I do know some toyotas do) You can swap different cars on the new OBD2 inspection stations BUT try to stay with the same generation model. I've done it multiple times at a friends shop. Your JDM OBD2 integra will fail emissions because of the different protocol. It does not use the ISO 9141 protocol.
I have had my car inspected about 4 times with the "new OBD2 inspection" and each time with a different ecu in my car. My car is a 00 civic, I have used a 98 civic ecu, 00 civic ecu (auto trans), 00 civic ecu (manual trans) and 2 different 98 USDM Type R ECU's (P73)
Does this answer your question
If you want to pass emissions you need a USDM P73 ecu. A 00-01 will not work (it has an immobilizer)
Old Jun 23, 2008 | 03:15 PM
EK9Rider's Avatar
good to know...
Old Jun 23, 2008 | 03:52 PM
Default Re: Does an ECU have info on the cars VIN ? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">ok, ALL USDM OBD2 96-00 civic and integras do not store the VIN# in the ECU. This is a myth. (Some VERY new cars, however, do store VIN#, exactly what cars I don't know, I do know some toyotas do) You can swap different cars on the new OBD2 inspection stations BUT try to stay with the same generation model. I've done it multiple times at a friends shop. Your JDM OBD2 integra will fail emissions because of the different protocol. It does not use the ISO 9141 protocol.
If you want to pass emissions you need a USDM P73 ecu. A 00-01 will not work (it has an immobilizer)</TD></TR></TABLE>
Does it have any sort of ID number in the ECU to make it specific to a car?
My car currently wont pass because it cant be read by a scan tool. If I put in a USDM ECU can a scan tool read from a JDM car? I am asking is the error the scan tool gets from the ECU or from the car? If its the ECU I will swap ecu's, if it is the car then I dont know.
Old Jun 23, 2008 | 03:58 PM
Luserkid's Avatar
JDM ecu's are not readable with scan tools. You need a USDM ECU and it will read scan tool.
Old Jun 24, 2008 | 04:54 AM
Default Re: Does an ECU have info on the cars VIN ? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote"> If you want to pass emissions you need a USDM P73 ecu. A 00-01 will not work (it has an immobilizer)</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">JDM ecu's are not readable with scan tools. You need a USDM ECU and it will read scan tool. </TD></TR></TABLE>
Ok so now my next question is if I put in a USDM ECU into a JDM ITR is it going to throw codes? The sensors and emissions stuff is different on JDM engines right? If i can swap ECU's and not gets codes so they can read the car then I would be done but I have heard the oil pump CKFS pully and sensor, secondary 02, EGR valve, VTEC pressure switch, Knock sensor and coolant switch are all different in JDM engines.
Will this throw codes or is it plug and play?
Modified by GoFastTshirts.com at 8:59 AM 6/24/2008
Old Jun 24, 2008 | 03:19 PM
sicones's Avatar
You need some of those sensors you just splurted out, but there are ways for "tricking" some of them. Mainly the CKF sensor and vtec pressure switch.
Old Jun 24, 2008 | 03:30 PM
Sr420Det's Avatar
whats the purpose of a immobilizer?
Old Jun 24, 2008 | 03:54 PM
B18CivicEJ8's Avatar
x2
CKF bypass is here: http://technet.ff-squad.com/ckftrick.htm
Vtec Pressure Sensor bypass is at the bottom of this page: http://technet.ff-squad.com/hybrid.92-95.obd2.htm
In addition to a conversion harness, those are the only two things I had to do to get a USDM OBD2A P72 GSR ecu to work on my JDM B18C OBD1 engine in an OBD2B 99 Civic EX. I was able to pass emissions just fine.
As for the secondary O2 sensor, I'd get a usdm cat w/ o2 sensor and add wires to your harness.
Old Jun 24, 2008 | 04:00 PM
01-0720's Avatar
Default Re: (Sr420Det)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sr420Det &raquo;</TD></TR><TR><TD CLASS="quote">whats the purpose of a immobilizer?</TD></TR></TABLE>
its a theft deterrent device in the ecu, it makes it so only one key with the right chip in it can start the car, it makes it harder to steal
Old Jun 24, 2008 | 04:03 PM
The immobilizer is basically a chip in the ECU that recognizes a RFID chip that is in a key in the ignition. If the key ain't in the ignition, the car won't start. Thieves have figured out how to bypass immobilizers and a lot of insurance companies refuse to believe that is the case. Consequently, they deny claims of theft because they believe it is impossible to move a car that is equipped with an immobilizer.
http://www.wired.com/wired/arc....html
accord_raffi
Mar 13, 2009 02:28 PM
baller status
Feb 2, 2009 01:25 PM
kadidle
Engine Management and Tuning
Jan 3, 2009 07:32 AM
a1320addict
Aug 7, 2006 06:16 AM
00civex
10
Dec 16, 2004 05:56 PM
