What size tires on 15x6.5 rims?
Old Jun 23, 2008 | 08:57 AM
Momentum's Avatar
Default What size tires on 15x6.5 rims?
Im picking up some 15x6.5 rims today, just wodnering what size of rubber i should be looking for?
195/40
195/50
205/40
205/50
I wanna use them for street use, also mild drag here and there
Old Jun 23, 2008 | 09:15 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: What size tires on 15x6.5 rims? (Momentum)
The best size depends on what kind of car they will be used on - year, model, version, etc. Care to share?
Old Jun 23, 2008 | 09:17 AM
Momentum's Avatar
Default Re: What size tires on 15x6.5 rims? (nsxtasy)
92 civic hatchback
tokiko 5 way adjustable struts
comp tech springs
Old Jun 23, 2008 | 09:27 AM
nsxtasy's Avatar
H-T Order of Merit
195/50-15.
If you're looking for a supersticky tire in that size, to do dual duty on the street and at the strip, you can get the Bridgestone Potenza RE-01R (USD115/tire at the Tire Rack, CAD160/tire at 1010tires.com) or the Toyo Proxes R1R (USD116/tire at onlinetires.com, CAD160/tire at 1010tires.com).
Modified by nsxtasy at 12:34 PM 6/23/2008
Old Jun 24, 2008 | 07:37 AM
Momentum's Avatar
116USD - 160CAD...
Not even clsoe to the current exhange rate. That exchaneg rate is at least a year behind aha
Momentum's Avatar
Default Re: (Momentum)
What about 205's?
Wider = better traction
I dont know much about tires but i just assumed 205's would be better, why choose 195s?
Old Jun 24, 2008 | 08:04 AM
randomtask77's Avatar
I use 205/50/15's with no problems
Old Jun 24, 2008 | 08:09 AM
Momentum's Avatar
Default Re: (randomtask77)
How do the 50's look on a 15" rim?
I dont want them to look massive...
Old Jun 24, 2008 | 09:20 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Momentum &raquo;</TD></TR><TR><TD CLASS="quote">116USD - 160CAD...
Not even clsoe to the current exhange rate. That exchaneg rate is at least a year behind aha</TD></TR></TABLE>
You're confused. I posted prices from two different dealers. The prices at the U.S.-based dealer, quoted in U.S. dollars, are less than the prices at the Canadian-based dealer, quoted in Canadian dollars, after adjusting for currencies. With the U.S.-based dealer, you will have to pay extra duty and it may or may not be cheaper than the Canadian dealer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Momentum &raquo;</TD></TR><TR><TD CLASS="quote">What about 205's?
Wider = better traction</TD></TR></TABLE>
Not necessarily. 10 mm of treadwidth isn't going to make a whole lot of difference. The big factor in traction is the tire's design, so if you're looking for better traction, concentrate on getting better, stickier tires, rather than wider tires.
195/50-15 is the better size for your car because the diameter is closer to your stock size, so it won't throw off your speedometer or odometer. Also, the smaller outer diameter (compared with the 205/50-15) will help your acceleration.
Old Jun 24, 2008 | 10:21 AM
Momentum's Avatar
Thanks for all your help!
poseghatch
May 23, 2013 02:51 PM
jdm_j03
Apr 24, 2009 07:27 AM
twentyhurtz
Nov 25, 2008 05:02 AM
$ugarFree
Jun 3, 2007 09:40 AM
still
Apr 7, 2006 02:35 PM
