exhaust manifold/header problem
Old Jun 23, 2008 | 08:22 AM
EJ6-2nr's Avatar
Default 6G DX "Coupe de' Bliss" aka<Project*Wifey>
Eric here, newbie to the forum, i have a question that can probably be easily answered:
my wifes civic; 97 EJ6, cal. emissions;
the exhaust manifold/converter has a crack in the top of it just above the 02 sensor housing, i want to replace this manifold/converter with a header but im finding a very limited amount of info on what header would fit, this is apparently because its cal. emissions. a friend told me that i could use an EX manifold/converter but the location of the sensor housings might require that i lengthen the sensors wires. might this be true? wether it is or not, i would still like to find a header instead, HELP!!!
Old Jun 23, 2008 | 08:31 AM
mortificationrock's Avatar
Default Re: exhaust manifold/header problem (EJ6-2nr)
Mind me asking how many miles are on your wifes car and are you getting a CEL?
Old Jun 23, 2008 | 10:49 AM
EJ6-2nr's Avatar
Default Re: exhaust manifold/header problem (mortificationrock)
170k, no CEL's. has new timing belt, o2 sensors and rear exhaust
Modified by EJ6-2nr at 1:33 PM 6/23/2008
Old Jun 26, 2008 | 04:56 AM
EJ6-2nr's Avatar
does this mean im SOL lol
Old Jun 26, 2008 | 05:38 AM
medjosh6's Avatar
YOU CAN USE THE EX MANIFOLD,JUST EXTEND THE PLUG FOR O2 SENSOR.
Old Jun 30, 2008 | 12:41 PM
EJ6-2nr's Avatar
Default Re: exhaust manifold/header problem (medjosh6)
thank you! As far as extending the wiring for the 02 sensor, can anyone give me some pointers on doing this?
Old Mar 18, 2009 | 10:07 AM
EJ6-2nr's Avatar
Parked the 97 sedan and bought this uber clean 98 coupe. Put the 16's on as soon as we got home, and i found a ft/rr lip kits and lowering springs online that i want
installed some bolt-ons: knockoff 4-2-1 header setup (catless) and a knockoff CAI
Old Mar 18, 2009 | 11:08 AM
EJ6-2nr's Avatar
ttt
Old Mar 18, 2009 | 11:39 AM
EJ6-2nr's Avatar
looking at getting some new 185/50 16 tires to replace the 205/55's on the vsr's, and then drop it on som skunk2 springs, jus lookin to go flush when i put the 205/50 summers on and hopefully it'll tuck a little with the 185/50's on
Old Mar 19, 2009 | 07:04 AM
EJ6-2nr's Avatar
bump
Old Mar 20, 2009 | 07:09 AM
EJ6-2nr's Avatar
ttt
Old Mar 20, 2009 | 09:48 AM
EJ6-2nr's Avatar
Going for this look with the 98, minus the wheels
Old Apr 20, 2009 | 09:12 AM
EJ6-2nr's Avatar
changed the plugs to NGK's (previous owner was running autolites lol) and the wires from crappy ebay ones to some ngk's
relocated the frt. liscense plate to the side to cover a hole/stab in the bumper cover lol
washed and waxed, paint still looks horrible, oh well
Old Apr 20, 2009 | 09:18 AM
EJ6-2nr's Avatar
polished up the headlights and then baked em, painted the bezels black and then resealed em, came out good. still need to paint the brakes up, and replace a broken PCV valve. its going to my friends shop on thurs. to get inspection, LOF and drivers front wheel bearing done.
Old Nov 17, 2009 | 07:39 AM
EJ6-2nr's Avatar
Updates:
oil changed to synthetic
replaced PCV
replaced fuel filter (what a bytch)
replaced both front w/b's
replaced both outer tie rod ends
alignment completed
axle-back muffler custom flanged/welded to stock center pipe
Still looking for:
integra seats
red carpet
floormats
shift ****
Old Nov 19, 2009 | 10:11 AM
EJ6-2nr's Avatar
gettin the lip this weekend, install in the sping
Old Nov 20, 2009 | 11:40 AM
EJ6-2nr's Avatar
^ scratch that, lip was not for an ek
Old Nov 21, 2009 | 11:07 AM
boxeocampeon's Avatar
this ***** really clean
Old Nov 21, 2009 | 11:32 AM
thumper64's Avatar
all your wtb stuff belongs in the classifieds.
Old Nov 23, 2009 | 07:19 AM
EJ6-2nr's Avatar
ya?
Old Feb 16, 2010 | 06:00 AM
EJ6-2nr's Avatar
new skunk2 springs (2" drop) and lips, grill, and shift ****, and maybe some nice oem cloth floormats are in teh mail
Old Feb 16, 2010 | 06:08 AM
EJ6-2nr's Avatar
wintah mode
Old Feb 18, 2010 | 07:46 AM
EJ6-2nr's Avatar
come on spring!
Old Feb 20, 2010 | 05:13 AM
EJ6-2nr's Avatar
traded for some used 205 50's nokian i3, so as soon as the snow melts the s2's, wheels and tires, lips, grill and shiftknob will all be going on, will have pics up next post
Old Mar 25, 2010 | 04:57 AM
EJ6-2nr's Avatar
crappy cell pic update, skunk2's are not in yet so its skyjacked bad
