Accord 97 Aftermarket Wheels
Old Jun 23, 2008 | 05:44 AM
naicul's Avatar
Default Accord 97 Aftermarket Wheels
I recently bought used Motegi 18" rims, from a guy who had them on his Accord 96. I put 2 new tires on to match 2 good ones already on, Wanli 225/40ZR18. My question is, are these wheels/tires too big for my Accord? The suspension has not been modified, and the wheels fit on good without any rubbing. Any help greatly appreciated.
Old Jun 23, 2008 | 08:15 AM
r.wright's Avatar
Default Re: Accord 97 Aftermarket Wheels (naicul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naicul &raquo;</TD></TR><TR><TD CLASS="quote">225/40ZR18. My question is, are these wheels/tires too big for my Accord? </TD></TR></TABLE> no but then that tire size is way too big. depending on what trim u have the tire should be 215/40-18
Old Jun 23, 2008 | 08:47 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Accord 97 Aftermarket Wheels (Opossum Jenkins)
Your Accord is a '97? What version (LX, EX, etc), engine (4 cyl or V6), and body style (sedan, coupe, etc)?
Old Jun 23, 2008 | 08:54 AM
naicul's Avatar
Default Re: Accord 97 Aftermarket Wheels (nsxtasy)
97 Ex 4 cyl sedan. I've gotten mixed opinions about whether they're safe on my car. Thanks.
Old Jun 23, 2008 | 09:24 AM
nsxtasy's Avatar
H-T Order of Merit
Your car came from the factory with 195/60-15 tires. 225/40-18 is really huge (3.6 percent larger outer diameter than stock). Tire Rack recommends 215/40-18, but even that is 2.3 percent larger than stock. If I were buying four tires, I would go with 215/35-18, which is much closer in diameter to stock (1.2 percent smaller). Since you already have two tires, though, it's like they're free, you may as well use them. I would get two 215/40-18 tires to go with the other two.
Old Jun 23, 2008 | 09:34 AM
naicul's Avatar
Thanx. All 4 tires are 225/40, so I can't buy 2 215's. I'm stuck with the 225's. Someone told me that my suspension will be severely damaged if I put the wheels on. I need a safe car for work and school. Am I better off selling the wheels and losing some money?
Old Jun 23, 2008 | 09:37 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naicul &raquo;</TD></TR><TR><TD CLASS="quote">Someone told me that my suspension will be severely damaged if I put the wheels on.</TD></TR></TABLE>
That's nonsense. If you can put them on your car and they don't rub, they won't damage anything.
Old Jun 23, 2008 | 09:42 AM
naicul's Avatar
That's what I thought too. I am however also a bit concerned with the weight of the wheels. They are significantly heavier than the factory 15" alloys. The 18"s look so good on the car
squareback
Mar 28, 2006 06:02 AM
