How Do I Read Check Engine Code For 93 Del Sol ?
Old Jun 23, 2008 | 05:07 AM
2.3AccordSOHC's Avatar
Default How Do I Read Check Engine Code For 93 Del Sol ?
Hi All
I am new here to the Del Sol area cause I just recently purchased one ...
I got a check engine light on and I don't know how to read it to see which code I am throwing ?
Also,
The car runs good until it warms up then when I put it into neutral the rpms fall to 0 and the car shuts off .... If I am sitting still at an idle the rpms fall to almost 0 then try to jump back up shaking the whole engine in the process ?
Any ideas or suggestion please ??
THANKS !!!
Old Jun 23, 2008 | 05:52 AM
gibsanez's Avatar
Default Re: How Do I Read Check Engine Code For 93 Del Sol ? (2.3AccordSOHC)
Jump the small two pin connector located underneath your passenger side dash/carpet by the ECU. Just use a small piece of wire, or a paperclip. A long blink is 10, a short blink is 1. The keys should be in the ign., but you don't need the car running.
Here is the list of codes.
https://honda-tech.com/zerothread/1710584
Old Jun 23, 2008 | 02:36 PM
itsmejto's Avatar
Hmmm, is there an actual code reader for obd1 cars ? where on a civic would it plug in ?
Old Jun 23, 2008 | 06:30 PM
gibsanez's Avatar
Default Re: How Do I Read Check Engine Code For 93 Del Sol ? (itsmejto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsmejto &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm, is there an actual code reader for obd1 cars ? where on a civic would it plug in ?
What do you think the 2 pin connector is for?
Old Jun 23, 2008 | 07:11 PM
rSol93's Avatar
Yeah if you dont wanna jump it, just go to autozone and they can read the CEL.
Old Jun 23, 2008 | 07:45 PM
Default Re: (rSol93)
I have a 93 Del Sol SI as well ... Mine is black ....
I went to auto zone today and they said that they can't read the code ... They gave me a 2 pin metal GM code key said it might work to read my car .... I just don't have faith in doing any of that stuff so I am going to take it to a import shop tomorrow ....
Old Jun 24, 2008 | 04:27 AM
gibsanez's Avatar
Default Re: (2.3AccordSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.3AccordSOHC &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 Del Sol SI as well ... Mine is black ....
I just told you how to read to codes yourself for free.
Old Jun 24, 2008 | 06:17 AM
h2392si's Avatar
Default Re: How Do I Read Check Engine Code For 93 Del Sol ? (gibsanez)
Look at the stickies on the forum, it's right there. Since you can't seem to follow simple directions here:
https://honda-tech.com/zerothread/1901557
grinch559
May 23, 2012 07:05 PM
del-sol-95
Feb 12, 2006 04:00 PM
vroomvroomcivic
Aug 31, 2004 05:05 PM
2camsaam
Oct 1, 2002 12:25 AM
CHEETAH
Jul 18, 2002 06:13 AM
