I have a question: 90 DA with Hydro, how does the VSS work?
Im about to purchase a type r tranny for my 90 integra with a b18c, now how will i go around the vss. Does the old mechanical gear cable mechanism fit where the vss goes into the transmission?
on some the use a magnetic pulse generator, how that works is that there is a ring like the one for your abs with the notches in it and there is a magnetic sensor that over hangs the ring, once the ring starts to spin the magnet is stationary the little notches make and then break a magnetic feild, the fast you go the quicker these signal breaks get closer together and more intense. hope this helps
is that for ur speedometer cable?
dont kno what a vss is but if ur tryin to use ur DA speedo into the Hydro Tranny...
i unbolted the sensor off the hydro tranny
and ull see a hole with a metal stick in it
take it out
and stick ur DA speedo in there.
thats what i did.
if ur talking about something else. than sorry for wasting ur time LOL
take it out
thats what i did.
i dont think it really matters between cable or hydro trans. when i swapped my b16 into my DA it had an electronic VSS and all i did was swap the cable VSS in and it worked fine.
RACEPAK
Nov 9, 2023 07:24 AM
