The gas meters on these cars suck
On my car, the meter will move from full to one bar down at 110 miles. and then at 160 miles im almost at half a tank, lol. but then the next 40 miles it'll move 2 bars to exactly half a tank. then from 200 to 250 it goes to 1/4 a tank. and 250-350 the other 4 bars to empty.
btw, is there a mod that makes the gas meter go down accurately. i dont like thinking i have less gas in my tank than i do
funny thing, i was thinking the same thing today also, i noticed that my car's gas fluctuates more than my suv or any other car i drive ... is there a reason behind this??? i too am curious
i love it when your parked up-hill and when you get in the car its like whoah i have alot of gas still
then 15 min ater driving that isnt so
its like WT*
its like WT*
Same here...oddly enough though, after running a tank with Techron, the gas gauge seems to operate more normal. Before, I would go 100 or so miles till it drops from Full, but now it drops after about 35 miles. I never put techron in my car to try and fix the gas gauge, but it is something I noticed after running it through. And sure enough, I read the ENTIRE bottle afterwards and it says it can help the sensors sense the correct fuel level...but I'm skeptical about that kind of stuff, so I'm not sure if it actually contributed to it.
I haven't ran the tank low enough to see how the low level goes. Before My light would come on, and then the next day it would show a quarter tank...
I think there was a TSB issued for this situation that called for replacing the the speedo/fuel gauge housing (having a brain fart and can't remember what it's actually called...). But hearing from others, it doesn't sound like it actually fixes the problem.
I am having this same problem with my gas gauge, where it would read half a tank, then the next time i turn the car on, it goes to empty. it took about 10 minutes for the needle to very very gradually get back up the accurate level reading. also, the other day i put about 3 gallons in my car when it read 'empty', and when i proceeded to drive out of the station, it went back down to read 'empty'. i checked, no leaks.
is there a way to fix this other than going to the dealership and getting the fuel gauge replaced? i'm going on a long trip soon, and want to make sure the gas gauge is in correct working order
after 100 miles my meter only moves 2-3 bars from a full tank.....then after a lil' over 200 miles im already at half tank....then the low gas light turns on after a lil' over 360 miles. wth?!
Its an inaccurate fuel gauge reading. TSB bulletin 05-002:
Symptom:
At any fuel level, the fuel gauge reading drops by 1/4
tank, or 3 to 4 graduation marks. In some cases, the
fuel gauge indicates “E†and the low fuel warning light
is on. After driving for several minutes, or cycling the
ignition switch off/on, the fuel gauge returns to the
correct reading. This problem is intermittent, and it
affects only Civics with Visteon gauge assemblies.
The corrective action lol: Replace the gauge assembly its only a problem with gauges made by VISTEON.
Symptom:
In my fuel and ignition class a couple years ago my teacher said that the gas meter is only accurate at full, half and empty. The rest is more of an estimate. Seems to be true in most cars.
