Blocked - Rear window washer - Help!
Rear Window washer fluid would not come out of the nozzle. The pump is working, the line is full. I have cleared out the nozzole hole with a thin paper clip.
How can I take off the nozzle? Can it be pulled off without damage?
It is 95 Teg.
HELP!!
It is 95 Teg.
HELP!!
I tried, and managed to break mine. But this is how you attempt it:
1) open hatch
2) remove the little button on your headliner in the rear center by twisting it with your finger
3) pull back the rubber that seals the headliner against the sheetmetal where the roof meets the hatch. The headliner can now be pulled down a few inches.
4) stick your hand in there and pull the washer tube off of the nozzle. Careful, some fluid may pour out, should be cleaned to prevent rust.
5) squeeze the plastic tabs on the underside of the nozzle and push it out the top. This is where I managed to break it.
HTH.
Rainmaker
1) open hatch
HTH.
Rainmaker
rasta420
Feb 5, 2005 05:15 AM
rice_classic
Jan 14, 2004 12:32 AM
