'95 Accord Hesitation/Bucking Problem
Old Jun 22, 2008 | 02:27 PM
bfrance's Avatar
Default '95 Accord Hesitation/Bucking Problem
Quick question: My '95 ex coupe recently developed a weird hesitation/stuttering issue when under light acceleration or steady state cruising. If you're between about 1750 rpm and 2800 rpm it will buck and stutter pretty bad, to the point that you can feel and see the car lurch. If you accelerate at 1/3 throttle or more, it seems to go away, and above 2800 it goes away.
Bad TPS? If so, what voltage range should it read on a multi-meter? I've gotten my meter on it, with the plug undone and it reads from .02-.06 through the range of travel, but it doesn't seem to be linear. It will start at 0, then as you open the throttle plate it jumps to .02, .04, then .06 at about half throttle and never goes above that reading.
HELP!!!!!
protheos
May 22, 2018 09:00 PM
Thathondakid
Jun 18, 2015 08:49 AM
jrnyfan11
Jan 3, 2014 12:19 AM
glen1
Oct 31, 2013 04:13 PM
tonysaccord
Jan 22, 2005 09:33 AM
