EVAP Purge Control Solenoid
Is the plug for the EVAP purge solenoid located on the Engine Wire harness? I just plugged everything up on my swap (94 H22A) and the EVAP Purge Control Solenoid was left out
Instead of using the purge control solenoid from the prelude, can I just use the purge "cut-off" solenoid found in my CRX HF?
skrew it, i'm just going to keep the HF's solenoid and plug in the vacuum lines on the charcol canister and H22 intake manifold. Let's see if the Ref. has anything to say about it.
Yea, I think pentaq is right. The plug for it is on the firewall, along with the plug for the MAP sensor. The engine harness does not have the plug for it. I was just wondering because the purge control solenoid came with my motor and it was hanging off of the intake manifold and I don't remember if I un-plugged it from the engien harness.
My issue right now is if I can utilize the Purge cut-off solenoid on my CRX HF <U>as</U> the Purge Control solenoid for the H22 swap to pass emission.
