boosted b18c or k20 swap
Ok i know this is a question for hybrids but i wanted other people thoughts on this subject. I was going to do a k20 swap costing me around 10k at the max. then i was thinking well may i should just boost my car and save money But then if i boost then i lose mpg and with the k20 i still get good mpg and power with out boost. What do you guys think b18c boosted or k20. Im looking for around 240horses with 180-240 torque. i know that thats kinda alot and for b18c it would be hard to get to that range but with the k20 it would be a little bit easier but more money. i would like to here both sides of the story
Boosted b18. You're gas milage will only suffer if you're raping your motor up to redline every time you hit the road. Lots of benefits to driving sane.
As soon as you put the K in, you're spending the extra money you would be saving on gas, right? lol. That's way too much money for way less performance you otherwise would have if you'd just boost the trusty B.
bseries are better go with the b18c... a friend of mine has a boosted b18c and he gets like 22mpg which isnt that bad and if its tuned right and driven right then you should be good..... good luck with all of that
deff go b18c boosted. you can piece a kit together pretty easy and cheap. my buddie went 12.7 with a stock gsr boosted and he kept that setup for 70k miles and his girl went 13.4 on a stock gsr boosted and only made 218hp. so i would deff. say go boost!
Now then if i didnt want turbo for my gsr and want to make it all motor would it better to just upgrade the valve train and still get close to my goal. lets say 210-220whp and 180tq
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRICED »</TD></TR><TR><TD CLASS="quote">Now then if i didnt want turbo for my gsr and want to make it all motor would it better to just upgrade the valve train and still get close to my goal. lets say 210-220whp and 180tq</TD></TR></TABLE>
Good luck getting those tq numbers on a stock block, you'll definately have to sleeve that baby and get a stroker kit.
can anyone tell me why i cant post...i wanna talk to this person about buying a car but it will not let me post it says i do not have permision..please pm me if u can help
good luck reaching those numbers without a fully built motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killakilla89 »</TD></TR><TR><TD CLASS="quote">can anyone tell me why i cant post...i wanna talk to this person about buying a car but it will not let me post it says i do not have permision..please pm me if u can help</TD></TR></TABLE>
go read the rules, you need more posts to do the cool stuff..
Go with a boosted B-motor. Even a stock LS on 10psi will make the power you want. All you will have to buy is injectors and get the ecu tuned. 220WHP on a stock LS motor is very common @10PSi on pump gas. The torque will be around 200 also. 10PSI on a stock GSR will get you even more power.
What motor is in the car right now? D16Z6's with forged rods/pistons and head studs can easily make 250 WHP and almost 200 LBS of torque. You can make that much power on a stock Z6 too you just need to be really careful with the tune.
I was thinking the exact same thing, I have a gsr turbo atm got stolen and well it seems like i need a new 1, so i was thinking hell why not a K20, but the fact of the matter is a k20 all motor wont give you any wear near the power a boosted gsr does. And the cost, at least 8k for the k20 swap + any mods, you can make a devil out of the gsr with 3- 4k or go moderate for the gas and get a small turbo that will still be way faster then a stock k20.
k20 all the way....overall the k20 is a stronger motor and if you decide to built the k20 in the future you can rack up alot of horsepower....i was in the same boat your are and im glad i went k20....im at 300hp all motor k20
dj theoretic
24
Feb 9, 2010 12:21 PM
