1990 honda accord. won't keep running.
Old Jun 22, 2008 | 10:26 AM
tbro's Avatar
Default 1990 honda accord. won't keep running.
i try to start the honda it turns over, fires ,runs for about a second then quits.all spark plugs have spark, and good gas flow to the fuel injection arm.
Old Jun 22, 2008 | 01:05 PM
Mr Yamada's Avatar
Default Re: 1990 honda accord. won't keep running. (tbro)
It might be worth the effort to remove the steering column shrouds and visually inspect the solder joints on the back of the ignition switch.
They should all look the same, not white frosted nor melted.
Also try letting the key back to run position from crank very slowly to see if the engine continues to run.
You can check for power from the ignition switch at the Black/yellow wire of the distributor plug after the car starts/stalls.
Main relay problems are also fairly common in warmer weather as well, however you say you have spark and fuel pressure when cranking.
trex352
May 24, 2012 01:48 AM
prem0626
Oct 20, 2008 11:54 AM
ebrathole
Oct 18, 2008 04:02 PM
nxsnrg
Apr 2, 2008 08:52 AM
lornaaaLALA
Feb 5, 2007 09:58 AM
