New Oil Pump?...new stock one, oem for different engine, or aftermarket?
Old Jul 18, 2002 | 02:45 AM
Gfunk176's Avatar
Default New Oil Pump?...new stock one, oem for different engine, or aftermarket?
i took my block in today to RS Motorworks in Carson Ca to get resleeved, pistons and rods put in and they told me to get a new oil pump. do you guys think that just replacing the stock one is fine or should i go with an upgraded one. do they make aftermarket ones for them....i have a b18c1 engine.
Old Jul 18, 2002 | 03:18 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (Gfunk176)
Get a new OEM oil pump. I know Im gonna get **** for this, but I stand strong behind this. Prodrive is crap!!
art
Old Jul 18, 2002 | 05:25 AM
Boost2NA's Avatar
Im gonna have to agree with Arturbo on this one. Stick with the OEM unit. I am currently building a block that will be pushing ove 400 horses and I am running a blueprinted gsr oil pump. Im not saying that prodrive sucks or nothing but a blueprinted stock one should work fine.
Old Jul 18, 2002 | 05:27 AM
DSF's Avatar
DSF
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (Arturbo)
Gonna use an OEM ITR pump on my +/-400whp build. Hope I don't regret it later
Old Jul 18, 2002 | 05:39 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (DSF)
650+whp on stock OEM oil pump. Ask Gary Kubo what he thinks of the prodrive oil pump gear.
art
Old Jul 18, 2002 | 11:25 AM
95TurboLude's Avatar
What about for H22's? Dr. Charles told me awhile ago when he was still with Atomic that the oil pump is the weak point on high horsepower H22's. Anyone know what oil pump people use on their 400+ whp H22's?
Old Jul 18, 2002 | 11:29 AM
KekeK-18's Avatar
I don't know, my stock GSR oil pump gear shattered with about 400whp....
Old Jul 18, 2002 | 12:05 PM
Rain_man's Avatar
New User
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (KekeK-18)
There must be a better alternative than OEM. How about the Toda?
Old Jul 18, 2002 | 01:53 PM
Farnsrocket's Avatar
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (DarksideDC4)
What's wrong with Prodrive oil pump gears?
Old Jul 18, 2002 | 09:57 PM
Flamenco-T's Avatar
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (Farnsrocket)
I actually met up and talked to Gary Kubo last week, and we actually talked about oil pump and benefit of oil squirters on street cars...and he believes very firmly on stock OEM oil pump.
Now, what does he thinks of ProDrive ? well, I saw a pic that most of you prolly will not like..but again it was on a 650plus HP..
so it's up to you..
I am using stock pump...
Old Jul 18, 2002 | 10:06 PM
VaporTrail's Avatar
New User
I have personally seen 3 oil pumps shatter, one on a car that was tuned perfectly (and not even by me). I have not experienced any problems with a Prodrive unit, except for mine which did not fit correctly. A quick call to Prodrive, and they sent me out another one, which fits fine. I'll put it to you this way - drop a OEM gear on the ground, see what happens.
Old Jul 18, 2002 | 10:56 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (VaporTrail)
I think the only thing that could shatter the oil pump gear is if they hit the rev limiter at a high rpm. How offten will a gear hit the floor in real life?
art
Old Jul 18, 2002 | 11:34 PM
synergy004's Avatar
all this talk about oil pumps and mah **** just went out. NO oil pressure, nothing. HEad wasnt getting any oil. made squeeking noise. **** was brand new too. Damn LS OEM pumps. POS ANy LS guys out there if you get a new one get a GSr one. OEM is good as long as its an upgrade from a higher model B series motor.
Old Jul 19, 2002 | 12:07 AM
VaporTrail's Avatar
New User
well lol of course the gear wont be hitting the floor, I was of course using that as an example (and an experience) but if you have a high vibration car (solid motor mounts, worn bushings, etc), or one with wheel hop, or a non harmonic balanced crank pulley (bad bad bad) then you could have this problem, tuned or not. It's the vibration that will cause it to fail. I've seen it too many times, and it can be quite destructive.
Old Jul 19, 2002 | 12:37 AM
Arturbo's Avatar
Better than steak
25 Year Member
I see what you mean john, but I have yet to see an oil pump fail. So until then Im gonna use it. Now those that have seen them fail, then Im all for getting a new gear.
art
Old Jul 19, 2002 | 12:49 AM
VaporTrail's Avatar
New User
I'd rather prevent than repair. Ounce of prevention....
Old Jul 19, 2002 | 12:47 PM
justagsr's Avatar
Damn, all this talk about OEM oil pumps...does anyone have one in stock b/c I'm needing one?
IM or e-mail me at mlself@csg.net
Old Jul 19, 2002 | 01:17 PM
boomslang's Avatar
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (justagsr)
I just got this reply from Vince at GE about stock vs. Prodrive...
"Well, I too speak with Gary Kubo on a regular basis and have heard all
the horror stories of the ProDrive oil pump. I too have felt the effects
of that pump in one of my sponsored cars. I built him a new design of
motor and we tuned it in, took it to the track and right out of the box
on brand new tires and a crappy 60 ft. time, he went 9.28 at 156 mph.
This was awesome. The next pass was to better the first, but the
ProDrive oil pump failed in third gear destroying the motor and ending
my trip all the way to NJ. I recommend nothing but stock now!"
Maybe this helps.
Old Jul 19, 2002 | 03:24 PM
gtcali's Avatar
Default Majestic Honda has 'em cheap
JustaGSR-
Check it out
http://www.hondaautomotiveparts.com
[Modified by gtcali, 12:26 AM 7/20/2002]
Old Jul 19, 2002 | 04:58 PM
Flamenco-T's Avatar
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (Inlinefour)
Maybe this helps.
the pic that I reffered to up top, is the pic of the car that vince is talking about...I saw the proDrive gear just shatter into pieces, it took me a good long look to figure out it was an oil pump gear...
stan
Old Jul 19, 2002 | 06:31 PM
Full-Race Geoff's Avatar
yeah that was sav from Impo, that sucked... too bad. he ended up getting another motor together but it wa a last ditch effort and the deck plate motor wasnt allowed to shine.
Old Jul 19, 2002 | 06:41 PM
Flamenco-T's Avatar
Default Re: New Oil Pump?...new stock one, oem for different engine, or aftermarket? (FFgeoff)
it was Leon's car...
stan
ISUBIEXI
Dec 11, 2017 05:54 PM
AllShowNoGo727
Apr 25, 2014 05:00 PM
chris.deyoung
Dec 18, 2007 01:18 PM
2uy
Oct 23, 2005 09:56 AM
