ZC and D16A6 the same?
Old Jun 22, 2008 | 03:41 AM
jtmoney2002's Avatar
Default ZC and D16A6 the same?
ok i got a dohc ZC and im about to rebuild my d16a6 to put in my 88 crx. But i was wondering if these blocks were the same , i know the sohc ZC are suppose to be the same but didnt know about the DOHC. i wouldnt think there would be a difference, i would think a zc block was a zc block. but figure id ask u guys, thanks jt
Old Jun 22, 2008 | 05:59 AM
zccr-xsi's Avatar
yea shohc zc is nuttin but a si motor,and the dohc zc is nuttin but a d16a6 with an extra cam.but as for rods IMO the a6 has stonger rods then the dohc zc
Old Jun 22, 2008 | 08:33 AM
jlicrx's Avatar
Default Re: ZC and D16A6 the same? (jtmoney2002)
DOHC ZC blocks are not the same as SOHC ZC or D16A6 blocks - head bolt holes in different locations - DOHC uses 11mm head bolts and SOHC uses 10mm head bolts - all of the DOHC ZC internals (except pistons) from the top of the block down are the same as the D16A6 - same crankshaft, oil pump, rods, water pump, timing belt tensioner, etc.
Old Jun 22, 2008 | 06:55 PM
zccr-xsi's Avatar
Default Re: ZC and D16A6 the same? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">DOHC ZC blocks are not the same as SOHC ZC or D16A6 blocks - head bolt holes in different locations - DOHC uses 11mm head bolts and SOHC uses 10mm head bolts - all of the DOHC ZC internals (except pistons) from the top of the block down are the same as the D16A6 - same crankshaft, oil pump, rods, water pump, timing belt tensioner, etc.</TD></TR></TABLE>
hes right ! i was talking about performce wise i said nuttin about aprts being the same, the dohc zc is nuttun more then a sohc with an extra cam. i would go with the sohc more support.
only real diiferance is the two are the topend!the dohc shares more of the teg parts and the sohc zc and a6 share the same parts.
Old Jun 22, 2008 | 08:16 PM
thanks jilicrx
4door93civic
Feb 1, 2008 08:46 PM
sohcvtec91hatch
11
May 4, 2006 05:24 PM
91hfrex
Feb 23, 2006 10:38 AM
scorched0
May 16, 2004 11:49 AM
pirocrxracer
Sep 30, 2003 05:38 PM
