99 gsr cluster in 90 civic LX (searched and refined)
Ok, so i've been searching like crazy to find the"how to" for a 0bd2 gsr cluster into my 90 lx...but nothing, ALMOST everything i found was for a obd1 gsr cluster. 94-01 is not the same!!!...i think its 94-96 then 97-01, found that out later...after 3 days of researching, i've put two diagrams together.....this is wat i came up with, so far...someone want to check this over for me?....I dont want to end up with a burnt wire under the dash or anything...
gsr cluster side----------------------------90-91 civic side
C
1 yel/wht - fuel gauge ---------------D6. Fuel Gauge --- (Yellow/White)
2 lt gr/red - dorr ajar------------------
3 empty
4 blu/wht - low fuel----------------
5 empty
6 orange - speedo
7 green - trunk light--------------D4. Trunk ---- (Green/Black)
8 red/blu - seatbelt---------------D5. Seat Belt ---- (Blue/Red or Blue/yellow)
9 red - dimmer----------------C4. Dash Brightness ----- (Red)
10 red/blk - gauge light----------------C5. Gauge Lights ----- (Red/Black)
11 blk/yel - power----------------------C10. 12v Power ---- (Black/Yellow)
12 empty
13 grn/blu - left signal------------------C1. Left Turn ---- (Green/Blue)
14 grn/yel - right signal-----------------D8. Right Turn --- (Green/Yellow)
15 red/grn - highbeam------------------C2. High Beam ---- (Red/Blue)
16 grn/red - E Brake--------------------C7. E-Brake ---- (Green/Red)
D
1 empty------------------------------
2 pink - maintence-------------
3 empty
4 yellow - power------------------D7. 12v Power ---- (Yellow)
5 red/blu - cruise------------------
6 blk - ground----------------D1. Ground ---- (Black)
7 yel/grn - temp gauge----------C3. Coolant Temp -- (yellow/Green)
8 empty
9 wht/blu - charging light------C11. Battery/Alternator Light ---- (White/Blue)
10 empty
11 yel/red - oil press-------------C8. Oil Pressure --- (yellow/red)
12 grn/org - check engine--------C9. Check Engine Light ---- (Green/Orange)
13 blue - tach------------------C12. Tachometer --- (Blue)
So this is what i have so far,, im missing a few things, so if you know..please fill them in...and i know i dont have the vss.(power/signal/ground)..i can figer that out later
C
3 empty
5 empty
6 orange - speedo
12 empty
D
3 empty
8 empty
10 empty
vtecn8ive
27
Nov 4, 2007 05:41 AM
eric.
Oct 17, 2002 04:30 PM
