So my motor is almost ready to go..........want your opinions.
Old Jun 21, 2008 | 06:10 PM
jaredvabeach's Avatar
Default So my motor is almost ready to go..........want your opinions.
Im really excited about my most recent motor build,Of course i was debating between going FI or NA and because of reliable issues i choose NA,just seems like the route where less **** breaks.
Soooo what ive put together:
95 b18c1 block bored over to a 81.5mm just to get a clean seal
CP 11.5:1 pistons
Eagle h beam rods with arps of course
all acl main,rod,and thrush washers
stock crank with aem lightweight pully
standard thickness oem honda head gasket
Aebs intake manifold
Type R throttle body
DC sports header
RLZ Ported and Mild Polish (shiny polishing sucks for air/fuel mixture just so you know)
GSR Cams (Cryo Treated) or might just use my TYPE R's
Aem cam gears
SuperTech Inconel Exhaust Valves
SuperTech Black Nitraded Intake Valves
5 Angle Valve "Job"
PortFlow Inner/Outer Spring Set
PortFlow Titanium Retainers
Manley Hardened Steel Retainers
97 GSR tranny non lsd,with stage 4 act clutch and 8lb. flywheel
Stock ignition system,injectors
So what is everyones opinion on my HP/TQ,all im hoping is to break 200whp,which i think i will only do if i get some aftermarket cams,in which case im going to get skunk 2 stage 2's
What are your opinions on cam shafts and other add ons,such as header,fuel supply,and igniton system......
Modified by jaredvabeach at 2:33 PM 6/22/2008
Old Jun 21, 2008 | 06:36 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: So my motor is almost ready to go..........want your opinions. (jaredvabeach)
All Motor forum rules:
4) E-Racing/Bench Racing/Guess my 1/4 or HP
There is no place for it here, it is not productive, frequently leads to arguments, and is generally pointless. Go find a dyno or a drag strip.
Old Jun 22, 2008 | 12:34 PM
anothersickhatch's Avatar
Default Re: So my motor is almost ready to go..........want your opinions. (00Red_SiR)
cheers to that
Old Jun 22, 2008 | 01:32 PM
Im looking for opinions on the build mainly.
Like which cam shafts are more preferred etc etc.........I asked about power so i can compare it to skunk 2's proven dynos so i know what would be overkill and not.
Old Jun 22, 2008 | 09:03 PM
i can think of 12 camshafts just off of the top of my head and a ton of guys would prefer.
its just a matter of you researching.
Old Jun 30, 2008 | 06:57 AM
I just went with skunk 2 stage 2 tuner series.
I will be getting tuned tonight so look forward to seeing my numbers.
Old Jun 30, 2008 | 07:13 AM
FST GSR 1's Avatar
Default Re: (jaredvabeach)
I am not a fan of using different valvetrain manufacturers, I don't get why anyone does that on springs and valves.
AEM cam gears, not a fan.
AEM undampened crank pulley
5 angle valve job...nevermind.
You won't make close to over 200 FYI.
Old Jun 30, 2008 | 08:37 AM
98vtec's Avatar
moderator emeritus
build it. Tune it. run it. post it.
scbmx87
118
Apr 7, 2009 11:35 AM
mr2turbo007
27
Nov 9, 2006 07:15 PM
allmotorek8
12
Sep 5, 2005 01:00 AM
ricearoni56
Nov 9, 2004 09:31 PM
n2ob16hatch
Oct 22, 2004 07:56 AM
