Temperature
Old Jun 21, 2008 | 02:10 PM
batallic's Avatar
Default Temperature
Is this a thermostat problem, when im idling my temperature goes to 3/4, the fan turns on and stays the same, i start driving and my temp drops to normal, coolant is full, the engine is d16z6
Old Jun 21, 2008 | 02:28 PM
thesmogman's Avatar
Default Re: Temperature (batallic)
When in doubt, change it out!
That is what it sounds like to me. Next time it starts to rise tap the gas and spin the motor up to 4k. Just a tap of the pedal and see if that will make the temps drop. Try it a couple of times. What it will do is put more water pressure/vacuum behind the t-stat and pull it open. If this does work then it is definately the t-stat.
ARMED
Honda CR-V & Element
May 3, 2014 09:28 AM
CUTTERSPOOL
Oct 21, 2012 11:05 AM
mf10_eg88
Jan 17, 2012 12:29 AM
litterbox
Mar 16, 2009 06:50 AM
90crvtec
May 26, 2005 08:53 AM
