Can't Buy This Honda Part? and a few questions...
So I need part 28 and it's not available on the list to buy; neither is part 21. I called Honda and Acura and they both said they don't know why I can't buy it and that it is very weird(they were stumped).
My questions:
I need to replace my A/C idler pulley because it has a bad bearing. Is the bearing in the pulley(part 19)?
It makes a light squeal and it's definitely from the A/C idler pulley area(not water pump bearing). Would ordering parts 19, 24, and 20 solve my problem?
1 38773-PJ7-003 CLIP, WIRE HARNESS 1 1997 INTEGRA 3.55 2.84 Qty:
2 38801-P9K-E01 VALVE SUB-ASSY., SAFETY 1 1997 INTEGRA 38.33 30.66 Qty:
3 38810-P9K-E01 COMPRESSOR (DENSO) 1 1997 INTEGRA 512.12 409.70 Qty:
4 38812-PH1-003 RING B, SNAP 1 1997 INTEGRA 6.12 4.90 Qty:
5 38812-671-003 RING A, SNAP 1 1997 INTEGRA 4.90 3.92 Qty:
6 38816-PR3-003 CLIP, LEAD WIRE 1 1997 INTEGRA 2.50 2.00 Qty:
7 38827-PH7-003 SCREW-WASHER (5X8) 1 1997 INTEGRA 1.80 1.44 Qty:
8 38829-PR3-003 BOLT, WASHER HEAD 1 1997 INTEGRA 2.63 2.10 Qty:
9 38838-P72-003 VALVE, SUCTION SERVICE 1 1997 INTEGRA 117.00 93.60
10 38839-PR7-A01 O-RING 1 1997 INTEGRA 9.02 7.22 Qty:
11 38840-PC1-003 BOLT B 4 1997 INTEGRA 5.00 4.00 Qty:
14 38900-P72-003 CLUTCH SET 1 1997 INTEGRA 193.33 154.66 Qty:
15 38912-PH1-N01 PLATE SET, WASHER 1 1997 INTEGRA 6.00 4.80 Qty:
16 38920-P75-A02 BELT, COMPRESSOR 1 1997 INTEGRA 15.80 12.64 Qty:
17 38924-P75-003 STATOR SET 1 1997 INTEGRA 82.95 66.36 Qty:
18 38941-P30-000 BRACKET, AIR CONDITIONER 1 1997 INTEGRA 33.85 27.08
19 38950-P3F-305 PULLEY ASSY. 1 1997 INTEGRA 44.67 35.74 Qty:
20 38944-P2T-000 COLLAR, IDLE PULLEY 1 1997 INTEGRA 4.98 3.98 Qty:
22 90023-P30-000 BOLT, FLANGE (8X90) 4 1997 INTEGRA 4.13 3.30 Qty:
23 90054-P30-000 BOLT, SPECIAL (10X30) 1 1997 INTEGRA 4.07 3.26 Qty:
24 90086-PR3-000 BOLT, SOCKET (10X28) 1 1997 INTEGRA 5.00 4.00 Qty:
25 90087-P30-003 BOLT, HEX. (8X84) 1 1997 INTEGRA 2.50 2.00 Qty:
26 94001-08000-0S NUT, HEX. (8MM) 1 1997 INTEGRA 0.48 0.38 Qty:
My questions:
Often times with those diagrams, several options are displayed. If the option is not used on a particular model, it is not in the list. The equivalent parts are 19, 20, 21, and 24. The bearing should be in part 19.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Often times with those diagrams, several options are displayed. If the option is not used on a particular model, it is not in the list. The equivalent parts are 19, 20, 21, and 24. The bearing should be in part 19. </TD></TR></TABLE>
That's my main concern.
When I called both dealerships they told me that if it doesn't apply to that model it won't be on that list. However, when I check every Integra model under several websites I can't find number 21 or 28 listed to buy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">Oh yeah, sorry. It is a 97' RS and I never took off the pulley to look if I need that part. I already ordered so hopefully I will solve the problem. You think it will?</TD></TR></TABLE>
I give it a 95% chance.
sorry if I make a little OT, I need this piece 9 38838-P72-003 VALVE, SUCTION SERVICE 1 1997 INTEGRA 117.00 93.60 but of course in Italy they sell the piece with all the compressor, someone knows tell me where to buy and especially that sends in Italy?
Thanks to all
Thanks to all
As you can see from the parts diagram, part number 28 is an assembly which consists of individual parts 19-20, 27, and 29-31. So you can buy those six individual parts instead of part number 28. HOWEVER...
Yup. When you look at the diagram, you can see that there are two different configurations for that area. One is with parts number 19-21 and 24, as Dogg mentions, and the other is for part 28 (i.e. 19-20, 27, and 29-31). The fact that your model only displays part numbers 19-21 and 24, and not 27-31, tells me that those are the parts for your particular model. Parts 27-31 must apply to some other Integra model, not yours.
rubens
May 30, 2002 02:46 PM
2005, 38810p72003, 38810p9ke01, 38839ph1003, 38920p75a02, 38950p3f305, 90054p30000, bad, civic, honda, integra, odyssey, plate, safety, set, stator, subassy, valve, washer
