ecu throwing error 15 code car wont start!!
i have 90 si civic thursday morning i went to work and the car work fine, then after my work around 3 i went to start my car and it wont so i thought of my self oh not again it happen to me this before so i waited 10 mins then went to start it again. it wont start still before thur i went to get new dis cap and rotor installed get new oil and all that, and today i went honda tech and found out about the main relay. i went to local junk shop and get a main relay put it on my car and still wont start and then i went to check my ecu and its blinking 15 times and i went online its says ignition output signal what is that. is that the whole distributor, spark plug or the wire, there is fuel cause i could smell the gas when ever im trying to start it, and how do you check fuel compression i need help gusy please help!!
man all i need is help! im in a hurry so i dont have time to do grammar right, i need really need help so for me grammar is later car first. ok so here is the problem, ecu throwing 15 so its ignition output signal. went to the junk yard to get main relay still no luck. bought dis cap and rotor, new spark plug and spark plug wire still no luck. i also bought new coil but still not starting, and i checked the spark plugs no sparks at all. what is the problem i can't figure it out please man all i need is help to get my car working again
Pay attention....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">code 15 ususally means that you need a new igniter in the distributor</TD></TR></TABLE>
stop wasting money on parts you don't need to fix your problem.
ILOVEYOURHONDA
20
Aug 6, 2013 01:06 PM
