99 Gsr Tranny Fluid****Gm syncromesh and Pennzoil Syncromesh???***
Old Jun 20, 2008 | 08:35 PM
SickIntegraWon's Avatar
Default 99 Gsr Tranny Fluid****Gm syncromesh and Pennzoil Syncromesh???***
Is there any difference between the two? Gm is faily pricey while Pennzoil syncromesh is available at local autoparts for much less. Ive used Gm's and it works great. Jusy wondering if anyone has used Pennzoil's before?
Thanks in advance
Modified by SickIntegraWon at 11:45 PM 6/23/2008
Old Jun 20, 2008 | 11:07 PM
inspyral's Avatar
Penzoil Syncromesh is not the same formulation as GM's Friction Modified Syncromesh. If, however, you find some AC Delco Friction Modified Syncromesh, that stuff is the same as the GM stuff, and the bottles you get at the GM dealer will usually just have a GM label stuck on over the AC Delco one. I would just stick with Honda MTF if you can't find the GM Friction Modified Syncromesh(it's become harder to find in some areas), since the non-friction modified stuff isn't the same thing.
Old Jun 21, 2008 | 02:56 AM
Default Re: (inspyral)
Yes, I figured it wasnt the same quality due to the price difference. Ill give the Honda MTF a try. Thanks bro
Old Jun 21, 2008 | 05:33 AM
97grnrs's Avatar
Default Re: 99 Gsr Tranny Fluid****Gm syncromesh and Pennzoil Syncromesh???*** (SickIntegraWon)
i been using penzoil sync. for about 2 years in multiple cars no problems...
Old Jun 21, 2008 | 05:50 PM
Default Re: 99 Gsr Tranny Fluid****Gm syncromesh and Pennzoil Syncromesh???*** (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i been using penzoil sync. for about 2 years in multiple cars no problems... </TD></TR></TABLE>
Yeah i figured it would be the same thing. Being that they are both syncromesh. I want to give it a try, but a bit skeptical over the price. . Thanks for all your input
Old Jun 21, 2008 | 09:30 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
straight 30w oil
Old Jun 21, 2008 | 10:15 PM
stealth50k's Avatar
Gm synchromesh friction modified is what i am doing this next time around. Heard its one of the best. Just stick to it if your already using it unless the penzoil is exactly the same.
Libertariat
14
Oct 18, 2006 05:48 PM
honda011
Jun 5, 2005 06:51 PM
3 G's
Feb 9, 2004 08:02 PM
KimChiKid
Aug 4, 2003 04:39 PM
R134
Feb 28, 2002 06:25 AM
