replica of jdm crx fog lights?
Old Jun 20, 2008 | 07:58 PM
need4jdm's Avatar
Default replica of jdm crx fog lights?
any aftermarket jdm crx fog lights replica in the market?
instead of spending few hundreds on the 20+ years used fog.
Old Jun 20, 2008 | 08:48 PM
~sp33~'s Avatar
EFB055
Default FV-QR
90 Prelude fogs? Im sure your local auto shop would have similarly shaped foglights too.
Old Jun 20, 2008 | 09:44 PM
HonDelso's Avatar
all 88-91 crx's had optional fogs. they are the same regardless what part of the world you go. Only difference would be the mounting brackets.
Old Jun 21, 2008 | 06:55 AM
~sp33~'s Avatar
EFB055
Default Re: (HonDelso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HonDelso &raquo;</TD></TR><TR><TD CLASS="quote">all 88-91 crx's had optional fogs. they are the same regardless what part of the world you go. Only difference would be the mounting brackets.</TD></TR></TABLE>
No they're not. But ok.
Old Jun 21, 2008 | 07:26 AM
kojack_0's Avatar
Default Re: (~sp33~)
some after market fogs you can find at a local pepboys, autozone, and advanced auto parts. and the part number is NV-102Z. theyre all the same on each store. they have a variety of colors to pick from. plus you can remove the black casing its in.
not the best but i love it.
heres mines.
Old Jun 21, 2008 | 11:35 AM
EE2bitsk's Avatar
those white fat 5's look sick. the fogs look alright, but i would have cut the bumper out right under the blinkers and mounted them there.
Old Jun 21, 2008 | 12:34 PM
hailchristian's Avatar
Default Re: (EE2bitsk)
Thats what i did. i got mine at napa for $20 bux.
after i get my bumper repainted should look decent.
Old Jun 21, 2008 | 01:47 PM
braass91's Avatar
Default Re: (hailchristian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hailchristian &raquo;</TD></TR><TR><TD CLASS="quote">Thats what i did. i got mine at napa for $20 bux.
How did you mount the fogs inside the bumper and which hardware did you use?
Old Jun 21, 2008 | 01:48 PM
Default Re: (braass91)
i just glued them in with some marine goop. they arn't going anywhere.
Old Jun 21, 2008 | 01:51 PM
braass91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hailchristian &raquo;</TD></TR><TR><TD CLASS="quote">i just glued them in with some marine goop. they arn't going anywhere.</TD></TR></TABLE>
Please, more detail as I am about to do something like yours since it's hard n expensive to buy the OEM fogs with mounting brackets.
Old Jun 21, 2008 | 01:54 PM
ill try to get a picture of it. I bought them at napa. busted out the dremmel. cut the whole smaller then the fog lights then slowly worked up the size till it was tight enough to hold the fog lights. got them aimed where i wanted them. then busted out the marine goop (from autozone) and glued them in. wired them up and it was good in the hood. i havn't had a single problem with them moving or anything. also i think the brackets that the fog lights came with are wedged on the back so that they couldn't be pushed out from the back of the bumper.
here ill go out side and see if i can snap a picture of the back of it.
Old Jun 21, 2008 | 01:57 PM
braass91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hailchristian &raquo;</TD></TR><TR><TD CLASS="quote">ill try to get a picture of it. I bought them at napa. busted out the dremmel. cut the whole smaller then the fog lights then slowly worked up the size till it was tight enough to hold the fog lights. got them aimed where i wanted them. then busted out the marine goop (from autozone) and glued them in. wired them up and it was good in the hood. i havn't had a single problem with them moving or anything. also i think the brackets that the fog lights came with are wedged on the back so that they couldn't be pushed out from the back of the bumper.
here ill go out side and see if i can snap a picture of the back of it.</TD></TR></TABLE>
To you I say, HailChristian!! Thanks.
Old Jun 21, 2008 | 02:09 PM
well i coudn't get a good picture but ill try again when im working on my car later today.
Old Jun 21, 2008 | 03:39 PM
kojack_0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE2bitsk &raquo;</TD></TR><TR><TD CLASS="quote">those white fat 5's look sick. the fogs look alright, but i would have cut the bumper out right under the blinkers and mounted them there.</TD></TR></TABLE>
haha thanks theyre dirty as h*ll though . well i didnt wanna cut the bumper so i mounted them there and everyone else got them under the blinker lights thats why. plus it looks meaner when its on at night. ill take some tonight and post it.
and $20 for replica/aftermarket fog lights are always a steal.
Old Jun 21, 2008 | 06:51 PM
crxfreak1117's Avatar
Default Re: (kojack_0)
i have the ones from advanced in my crx cost $17
Old Jun 22, 2008 | 05:08 AM
vtecb18c's Avatar
Default Re: replica of jdm crx fog lights? (need4jdm)
passwordjdm.com...they had a pair of jdm square yellows for sale im sure they can get more
Old Jun 22, 2008 | 09:39 AM
Spikey640's Avatar
Default Re: replica of jdm crx fog lights? (vtecb18c)
do the mount mount right on?
and did you just wire the fogs to your headlights?
Old Jun 22, 2008 | 11:59 AM
EE2bitsk's Avatar
replica JDM fogs for $20 FTW
Old Jun 23, 2008 | 02:21 AM
need4jdm's Avatar
thore fogs from epboys, autozone, and advanced auto parts - plastic or glass?
Old Jun 23, 2008 | 07:09 AM
kojack_0's Avatar
Default Re: (need4jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by need4jdm &raquo;</TD></TR><TR><TD CLASS="quote">thore fogs from epboys, autozone, and advanced auto parts - plastic or glass?</TD></TR></TABLE>
glass with black plastic casing. and its easy to wire up too.
Old Jun 23, 2008 | 10:16 AM
wiZCo's Avatar
Stouts 'n' Scotch
Autozone carries APC #505010A in clear and yellow, they are very close to OEM look.
Mounting involves drilling a hole in your bumper support, I have no idea hwo to go about the wiring if you don't have it already.
Old Jun 23, 2008 | 11:15 AM
crx_si-r's Avatar
Default Re: (wiZCo)
if you want the wiring harness for the fogs pm me, im goin to be making exact duplicates of the OEM harness from fogs to relay to switch.
Old Jun 23, 2008 | 12:08 PM
Red_ED8's Avatar
Default Re: (crx_si-r)
^^^^ thats what I'm doing ^^^^
Old Jun 23, 2008 | 12:31 PM
EE2bitsk's Avatar
word how much you looking to get for the harneses'?
Old Jun 23, 2008 | 01:05 PM
HonDelso's Avatar
they are same, only the mounting brackets are different. theres been a few threads on this very forum with pictured proof. and i have owned a crx with factory fogs.
